Magneto Headlights
Magneto Headlights
Post by Original Smith » Sun Jan 13, 2019 10:16 am
Do you think having the focus screw at twelve o'clock has anything to do with the fact the headlights are magneto, or just a coincidence?
Re: Magneto Headlights
Post by Rich Eagle » Sun Jan 13, 2019 11:02 am
I vote for coincidence but an interesting question.
Post by Mark Gregush » Sun Jan 13, 2019 12:50 pm
I would go with just coincidence because you could get cars with mag powered lights up to 1926.
Danny Lorenzi
First Name: Danny
Last Name: Lorenzi
* REQUIRED* Type and Year of Model Ts owned: 14 roadster, 23 cutoff pu
Post by Danny Lorenzi » Sun Jan 13, 2019 3:21 pm
Larry I am learning
Danny Lorenzi anything OLD
KMcoldcars
First Name: Keith
Last Name: McGowan
* REQUIRED* Type and Year of Model Ts owned: 1916 coupelet
Post by KMcoldcars » Sun Jan 13, 2019 8:56 pm
From what I understand having the focus screw at 12 o clock is the way to identify 1915 headlights. The later headlights have the focus screw at the side of the connection.
I own a 1936 Packard convertible sedan, a 1916 Model T coupelet, and a 2007 Mercedes Benz SL550 roadster.
Post by DanTreace » Sun Jan 13, 2019 9:58 pm
Ford provided 7 different styles head lamps for the T, and different mfg. too.
So the 12 O'clock adj. screw location was used on the early electric in 1915, but then can be found on headlamp buckets up to 1920 or so depending on the style of headlamp.
Typical 12 O'clock
Of note, all the 12 O'clock buckets do have the first style post fitting, the straight edge type.
This lamp is the T-6511-CX which is the 'two bulb' style used 1919-1920 and it has the 12 O'clock adjustment screw.
The small grommet hole under the larger socket is for the dim bulb wiring, which is separate from the bright beam wire, the special reflector has two holes and the dim bulb is 2 c.p.
