Timing Cover Alignment Tool for 1912
Posted: Fri Jan 06, 2023 9:43 am
by Distagon2
I am planning to change out the front timing cover on my 1912 to allow use of a "standard' timer versus the setup with an integrated oil spout. That takes me to needing an alignment tool. I have the tool for the later cars but the 1912 cover is different and requires a larger alignment tool that works by aligning the outer edges where the timer itself rides with the camshaft. I borrowed one years ago from Ken Jones and I believe it was an original tool. I looked at what the vendors offer and they all appear to be for later cars. Anyone know where I can find one, or have one I can borrow?
Re: Timing Cover Alignment Tool for 1912
Posted: Fri Jan 06, 2023 9:49 am
by Distagon2
Posted: Fri Jan 06, 2023 10:19 am
by TWrenn
One of the guys on here makes em and sells em. I got one but I forgot his name. It was either Dan Treace or Dan Hatch.
Posted: Fri Jan 06, 2023 11:09 am
by RajoRacer
Gene French produces the full size version.
Posted: Fri Jan 06, 2023 11:16 am
by TWrenn
Yeah!! That's who I got it from!
Posted: Fri Jan 06, 2023 10:32 pm
by Distagon2
Anyone have contact info for Gene French. I have found emailing and messaging through this site doesn't seem to work for me.
Posted: Sat Jan 07, 2023 12:46 am
by JTT3
It was in the eBay link.
Posted: Sat Jan 07, 2023 7:44 am
by Ralph F
Just curious as to why a later timer alignment tool wouldn’t work?
Ralph
Posted: Sat Jan 07, 2023 8:57 am
by Distagon2
The reason the later alignment tool won't work is because the area around the camshaft seal is different on the early cars than the later ones. If I can get some pictures together it would show it clearly.
I ordered one from the ebay link I already posted. Doh! It appears that is Gene French.......I ultimately get in focus!
Posted: Sat Jan 07, 2023 9:58 am
by Gene_French
Gregory:
your centering gage is on it's way ... sent priority mail yeaterday ...thank you Gene French
