New clutch drum
Posted: Sun Jan 08, 2023 9:11 pm
I am in the process of making a couple new clutch drums. The only dimension I am missing is from the face the washers right against to the set screw hole. Obviously that is critical. I know there were two different numbers for early cars and late cars. At least that is what I understand. Does anybody have that dimension or a drawing?
Thank you in advance.
