Holley carburetor evolution
Posted: Tue Jan 10, 2023 3:36 pm
I don’t know that I’ve seen this discussed here before but here are some minor differences in the body castings of the later Pat’d Dec 22, 1914 Holley G carburetors and the earlier Pats Pending carburetors and how they evolved from the 1912 H1. The 1913 Model S, while similar in design, was significantly different.
A telltale feature you can spot without disassembly is a 1/16” hole in the throat which allows gasoline from the intake manifold to drain back into the mixing chamber on the later models.(first picture)
The Pats Pending and H1 lack this feature but have a series of 6 holes drilled around the top of the area directly under the top of the jet, whereas the later models only have one hole there. (second and third pictures).
The jets for the H1 (left) and Pats Pending (center) have a keyhole slot with the H1 having a slightly differently shaped basin. The later version has only a round hole with 4 passages cross drilled towards the top. The idle pickup tubes and their fittings are slightly different as well with the H1 being round and tapered at the bottom while the Pats Pending and the later G’s use a tube flattened at the bottom and the fitting is more rounded at the screwdriver slot.(last picture).
The venturis interchange as will the throttle arms but their profile and hole spacing is a little different. Also the H1 mixing chamber covers seem to be smooth on the flat top area where the Pats Pending and later are a rough casting finish. May not can tell from the picture. Just things I’ve noticed over the years but never seen brought up.
