Purchased ParTs
Topic author - Posts: 1036
- First Name: bryant
- Last Name: shafer
- * REQUIRED* Type and Year of Model Ts owned: 1926 tudor
- MTFCA Number: 51736
Purchased ParTs
I love getting new to me parTs in the mail
I received these NOS rear spring shackles today. Found on T-bay 70$ to my door. Not bad! What have you purchased for your Model T lately?
Bryant
Bryant
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Re: Purchased ParTs
I’ve had a few sets of nos shackles over the years that required an oversize reamer thru the bushings to install. About .010” oversize if I remember correctly.
- MTFCA Number: 16175
- MTFCI Number: 14758
Re: Purchased ParTs
Today I ordered new leather for my 1916 hood. Tomorrow I'll stop at the saddle shop and pick it up.
Re: Purchased ParTs
Push/pull switches +
one is 1914/15, a 1915 (longer cylinder than the others, rest, yellow dot, are original not repros. One horn button complete All work!
- Last Name: shafer
Re: Purchased ParTs
Thanks for the tip! I will be measuring. Iam wondering if vendors sell bushings for NOS shackles?
Bryant
- First Name: Adam
- MTFCI Number: 1
Re: Purchased ParTs
The vendors won’t have oversize bushings. Measure yours first or try them in a new bushing. The ones I have had that were oversize were definitely “non standard”. I suspect that is how some of them have lasted all these years in unused condition. If yours are oversize, you can get a reamer to ream the new bushings after you install them. If you shop around, a reamer should be around $20 or less online.
- MTFCA Number: 121
- MTFCI Number: 16310
Re: Purchased ParTs
I like ebay because good NOS parts show up all the time. I would never think of using anything other than a good used or NOS shackle for any of my cars. I also use brass bushings. In the past mild steel bushings were used, but there is no need to do that anymore.
- First Name: Adam
- MTFCI Number: 1
Re: Purchased ParTs
Brass and bronze aren’t the same thing.
I bet you mean bronze.
- Last Name: shafer
Re: Purchased ParTs
I do have some bronze bar stock. Might have to fire up the atlas.
Bryant
Bryant
- Last Name: shafer
Re: Purchased ParTs
Mail man brought me a good spec transmission shaft! I like Christmas multiple times each month
Bryant
Bryant
Re: Purchased ParTs
Bronze bushings to suit can be bought off the shelf form suppliers. They are excellent candidates for custom reaming to size.
- Last Name: shafer
Re: Purchased ParTs
Bryant
Re: Purchased ParTs
Bryant add an extra note to self. Check funnel attachment to tube. Bronze joint if it appears compromised/poorly attached.
