Spinning your wheels
Posted: Fri Jan 20, 2023 10:43 am
by Rich P. Bingham
This one might be an '09 ? Flat belt off the rear wheel is powering something in that barn. I don't think I've ever seen a horn bulb mount like that one. Looks practical !
Re: Spinning your wheels
Posted: Fri Jan 20, 2023 10:50 am
by JTT3
I’d say late 9 based on the 2 bolt front body mount, tulip seats front & back, butterfly rear fender brackets are under the skirt not through the fender apron & tapered spokes. I can’t identify the side lights to big for JB 60’s & tiers are different, oil fonts are different. I’m relatively positive that the headlights are JB.
Posted: Fri Jan 20, 2023 11:06 am
by Humblej
Looks like it may have the ford script with wings on the radiator, Piquette manufactured car?
Posted: Fri Jan 20, 2023 11:15 am
by TWrenn
Running boards look '09 as does the headlamp. Is that some sort of animal curled up in the driver's area? Too blurry to tell for sure.
Posted: Fri Jan 20, 2023 12:20 pm
by Rich P. Bingham
Looks like a pup in the driver's seat. He moved!
Posted: Fri Jan 20, 2023 12:27 pm
by Rich Eagle
I think the Tourabout was not offered until July 1910 so it wouldn't be called a '09.
Correct me if I'm wrong.
The license plate looks like a 1912 Ohio if I am seeing it right.
Posted: Fri Jan 20, 2023 2:14 pm
by Scott Rosenthal
Like you said Tim, 09, based on 2 hole front body mounts, no reinforcing plate in radiator, and scalloped cut rear apron. Dog ID a bit tougher.
Posted: Fri Jan 20, 2023 3:40 pm
by Kerry
The Saturday evening post, August 1909, one of the 6 body styles for Fords.
Posted: Fri Jan 20, 2023 3:55 pm
by Rich Eagle
I appreciate the picture, Kerry. According to the model T Ford encyclopedia, the "Tourabout shown in Ford Times but not produced until July, and then called 1910 cars."
"MODEL YEAR DATES: October 1908 to July 31, 1909. (Ford called the cars built after July 31 1910 models."
So, I was wrong about it being July 1910 but rather July 1909.
Sorry.
