Inner axle bearing depth?
Posted: Sat Jan 21, 2023 11:47 pm
by bmklawt
Rebuilding the axle on my 1927 Touring and found my right axle housing is bent, scrounging through a few axles I have, I have noticed on some axle housings the depth of the machined area for the inside bearing is 4.150" and some are 4.290". The deeper ones have a step at 4.100" for the bearing race to sit on, the out side bearing machined area are all 4.150" deep.
Whats the difference and can I mix and match them?
Re: Inner axle bearing depth?
Posted: Sun Jan 22, 2023 12:00 am
by Adam
That is wear. The end of the bearing cage has worn that material away.
Posted: Sun Jan 22, 2023 12:03 am
by Kerry
In that time frame of the improved T, Ford introduced the inner seal for the outer bearing and machined room for it, sometimes when fitting a modern seal to earlier housings, you need to trim the sleeve back a bit to fit the outer seal so it will clear the hub.
Posted: Sun Jan 22, 2023 12:12 am
by Kerry
Also your photo shows that the sleeve is on the wrong side, the hole needs to line up with the grease dope cap.
Posted: Sun Jan 22, 2023 12:25 am
by Kerry
Posted: Sun Jan 22, 2023 7:16 am
by Jerry VanOoteghem
That's an inner bearing. No "grease dope cap" there.
Posted: Sun Jan 22, 2023 3:14 pm
by Kerry
Could be Jerry.
