Cast Iron High Compression Head
Posted: Fri Jan 27, 2023 11:37 pm
by Model T Ron
I think I am going to stay with the stock cast iron head but does anyone make a cast iron high compression head for the T?
Re: Cast Iron High Compression Head
Posted: Sat Jan 28, 2023 1:57 am
by HalSched
\If you shave the head you increase compression a little but the cooling system runs fairly close to the bottom. If you take off too much you coiuld cause a coolent leak into the block (cylenders).
Posted: Sat Jan 28, 2023 2:58 am
by TRDxB2
A Low head has slight higher compression than a high head.
- 569765.jpg (60.72 KiB) Viewed 1998 times
Posted: Sat Jan 28, 2023 8:18 am
by John kuehn
“I hopped up” my 21 Touring with a low head that I bought with a 17 engine. If I remember. the earlier T’s with the low heads had about a one HP boost then the later high head T’s.
Of course a T’s weight has a little to do with its performance. We have to remember a stock T is around 20 HP more or less and there is only so much you can do with 20-21 hp.
If you mill a high head you might get closer to the performance of a low head. BUT that’s my opinion and others will have theirs. Max milling on a high head is 60 thousands or so I’ve read.
Posted: Sat Jan 28, 2023 8:35 am
by TWrenn
Model T Ron wrote: ↑Fri Jan 27, 2023 11:37 pm
Altho I'm assuming you're not into a rebuild...but..why not use H.C. PISTONS? That's what I got on two of my Ts, but of course that was at rebuild time. However, "everyone" tells me you can swap out pistons with the engine in the car, it just aint super easy. Depends I guess on how badly you want this extra power I guess.
Posted: Sat Jan 28, 2023 9:41 am
by Scott_Conger
A period Waukesha head will have a vastly improved combustion chamber and yet adds very little additional compression. It gives very solid performance improvement with little to no additional stress on the bearings. I love them. And they're cast iron.
Posted: Sat Jan 28, 2023 10:01 am
by TXGOAT2
Compression aside, the stock T combustion chamber is about as bad as they get.
Posted: Sat Jan 28, 2023 9:21 pm
by Model T Ron
Scott_Conger wrote: ↑Sat Jan 28, 2023 9:41 am
Does anyone make them today or do you just need to find an original? Does anyone have a photo of a Waukesha head?
Posted: Sat Jan 28, 2023 9:29 pm
by Scott_Conger
some good pix and info here:
http://www.mtfca.com/discus/messages/80 ... 1239063958
and here:
http://www.mtfca.com/discus/messages/25 ... 1350846062
they were made in the same time frame as the T for both T cars and some industrial engine/agricultural uses
