Headlight Restoration
Topic author - Posts: 4
- First Name: Bob
- Last Name: Thompson
- * REQUIRED* Type and Year of Model Ts owned: 1914 Model T Touring
- MTFCA Number: 155
Hello All, I am restoring my Model T 1914 headlights. Would anyone know the shade of back paint I should be painting the inside of the headlight housing (glossy black, satin black, flat back, jet black) ?? Bob
Re: Headlight Restoration
I am not the authority on the subject, but after looking at a couple of original unmolested brass lamps, the paint looks like a flat black to me. This makes sense to me as I assume they wanted to minimize internal reflections in the lamp. Of course, I could also be looking at oxidized paint after lo these many years. I too am interested in knowing the precise answer to your question.
- First Name: Les
- Last Name: Schubert
I can’t imagine that they were originally painted differently inside than the outside.
- First Name: Rich
- Last Name: Bingham
I agree with Les. Mine were restored 20+ years ago same paint inside and out. The reflecting mirror focuses the light beam, any gloss from the inside of the bucket doesn't affect that.
Get a horse !
- MTFCA Number: 1219
Most black lamps I have seen were the same paint inside and out. They may well have dipped them in gloss black paint. Quick and easy.
That's my theory.
That's my theory.
This lamp has its original paint and even a run I believe was from the dipping process. It looks like it was glossy to me.
I don't doubt you for a second. Other than unpainted primer in small select spots that were covered with wood, I have never seen any evidence for anything other than what could be described as "glossy paint" on any single part of a T. Black or otherwise.
NH Full Flow Float Valves
- First Name: Rich
I'm sure many manufacturers besides Ford availed themselves of the same paint. I wonder who made it ??
The "any color so long as it's black" legend is misunderstood. The economy of "gilsonite" black and its durability dictated black pigment, because the varnish made by "cooking" gilsonite in drying oils was too dark to allow for pigments other than carbon black to literally show their colors. Gilsonite is a fossil resin akin to asphalt but much harder.
Get a horse !
