Ford Script High Compression Head
Posted: Mon Jan 30, 2023 9:07 pm
by Model T Ron
Does anyone make a high compression head with the Ford script and made is USA cast into it?
Re: Ford Script High Compression Head
Posted: Mon Jan 30, 2023 9:52 pm
by JTT3
Ron because licensing the Ford name cost the person more money making a product some consider that & leave it off. You’ll have to look at swap meets, the forum classifieds & tBay for ones produced late late 70s & 80’s. Reeder is the one person I can think of that made aluminum low heads with the Ford cast into the head.
Posted: Mon Jan 30, 2023 11:03 pm
by Allan
Ron, my Prus alloy head has the Ford script and Made in Canada. I added them. I made a little dam with plasticine for each word, and filled it with Devcon. Then i drew the lettering on the hardened Devcon and hand carved the lettering using an Exacto knife and my Dremel tool . It even has the casting date of the original iron head. Once painted, no-one has ever noticed it was there, let alone questioned the origins of the head.
Posted: Tue Jan 31, 2023 12:13 am
by frontyboy
Here is the guy in Michigan that has new hi compression aluminum heads with Ford script and made in usa. These are the Z combustion chambers. He states that a model t engine will develop approx 27 horse power with this head. The new head holds an additional quart of water. The head weighs 15 pounds. The price is $330 including shipping and boxing. The Ford script is nice and sharp and well defined. I just received my 2nd head from him and the quality is perfect. The machined head surface is just a din finish, which is the same spec that I use on Ferrari's and Subaru aluminum heads.
contact, Steve Zajicek
586-983-9771(Warren Michigan)
You won't be dissapointed!!
frontyboy
Posted: Tue Jan 31, 2023 1:08 am
by Allan
Wasn't it Ralph Zajicek who made the Z head? Perhaps Steve is a son/relative. Z heads have been available for a long time.
Posted: Tue Jan 31, 2023 3:09 am
by Vonau
Allan, I would be interested in your work. Do you have pictures of how you made the "Made in Canada"?
greetings from Switzerland
Posted: Tue Jan 31, 2023 8:38 am
by Alan Long
I’ve had a “Z” Head on my 1926 since 2004 and fingers crossed all is well!
Posted: Tue Jan 31, 2023 9:16 am
by JTT3
Just asking, are the above mentioned heads low heads. I really don’t know. The OP has a 1915 T.
Posted: Tue Jan 31, 2023 10:46 am
by KWTownsend
The only low head with Ford script that I know of is the Reeder Head. Out of production for decades now, they turn up in classified ads and at swap meets occasionally but getting really hard to find . I love mine.
Posted: Tue Jan 31, 2023 10:58 am
by JTT3
Keith that was my thought but I mislabeled them as Reed, since corrected in my previous post, & you’re right it is a great head.
Posted: Wed Feb 01, 2023 12:18 am
by Allan
I had a Reeder head on my speedster, and it worked really well, until it blew a head gasket between now 2 and 3. The head has a large void in that location, which corresponds to nothing in the block. I had it plated/welded shut, and had the head surfaced. Never had another problem. A mate in New Zealand had exactly the same experience.
Posted: Wed Feb 01, 2023 12:22 am
by Allan
Vonau, I did not take pictures when doing the work. I copied the embossing from the original cast iron head that was on the motor, and included the casting date, just because I could!
Posted: Wed Feb 01, 2023 12:46 am
by TRDxB2
Posted: Wed Feb 01, 2023 11:14 am
by Oldav8tor
I have a Z head on my '17. It does have "Ford" cast into it. The engine has been run on a dyno and achieved 27.32 HP at 1750 rpm with a NH carburetor, 22.65 HP at 1750 rpm with a Holley G.
Posted: Wed Feb 01, 2023 6:17 pm
by ModelTWoods
The 'Z' Heads have always been high heads and had Ford Made In USA on them. Prus heads are high heads and are plain with no markings. They are the only heads being produced (in stock configuration) presently that I'm aware of.
Posted: Wed Feb 01, 2023 6:27 pm
by Allan
"In stock configuration" If this is a reference to external appearance, they do look like standard heads, minus the lettering in some cases.
There is nothing stock about any of the combustion chambers. That is the whole purpose of their manufacture.
Posted: Wed Feb 01, 2023 6:32 pm
by ModelTWoods
Allan wrote: ↑Wed Feb 01, 2023 6:27 pm
Allen, I was referring to external appearance. I have one of both heads and do know the combustion chambers are different.
Posted: Wed Feb 01, 2023 7:39 pm
by Arbs
Allan wrote: ↑Mon Jan 30, 2023 11:03 pm
I'd love to see a photo if you have one handy.
Posted: Wed Feb 01, 2023 11:31 pm
by Allan
Photos as requested.
Posted: Wed Feb 01, 2023 11:46 pm
by frontyboy
Let me correct a previous post that new heads with Ford script not made anymore WRONG!!!! I just purchased my 2nd one and had it delivered last week. It is true that from time to time they might not have one in stock but a couple of weeks after you order and its on the way to you.
frontyboy.
Posted: Thu Feb 02, 2023 8:58 am
by Mark Nunn
That is excellent craftsmanship, Allan. Very well done.
Posted: Thu Feb 02, 2023 11:45 pm
by Arbs
Allan wrote: ↑Wed Feb 01, 2023 11:31 pm
Nicely done!
