Has anyone seem one of these or have them in their collections?
It looks useful, but did it actually work? I would think NOT to use this when the engine is running as the little ball would be a blur to see I guess.
But could be a bonus when turning over slowly as that would show both TDC and spark firing in one tool.
Stevens Timing Tool
Topic author - Posts: 1015
- First Name: Adrian
- Last Name: Whiteman
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT, 1924 Colonial Roadster, 1924 'Bullnose' Morris, 1925 'Bullnose' Morris, 1936 JD AR
- First Name: Mike
- Last Name: Cushway
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
- MTFCA Number: 52588
Re: Stevens Timing Tool
Cool tool! It almost had to utilize a piston against a spring calibrated to a new compression pressure. Weak rings or leaky valves and I doubt it worked as intended. Nevertheless a neat idea.
- MTFCA Number: 1219
Steven King posted this nice picture of one a few years ago.
http://www.mtfca.com/discus/messages/82 ... 1531292223
- Last Name: Humble
- * REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
- MTFCA Number: 28034
They are for moving the crank slowly by hand to find TDC and timing.
- First Name: Donnie
- Last Name: Brown
- MTFCA Number: 49575
I have one, but never tried to use it.
- MTFCA Number: 16175
- MTFCI Number: 14758
There have been several fancy doodads to set timing over the past 100 years. Currently Lang's sells one that even lights up (for $87). They are all less accurate than going by the pin position, which has the advantage of costing the perfect price — nothing. https://dauntlessgeezer.com/DG97.html
