10 tooth pinion question
Dennis Prince
Last Name: Prince
MTFCA Number: 22802
Post by Dennis Prince » Sun Feb 05, 2023 2:25 pm
I have a 10 tooth pinion that is marked 10-42, will that work on a 40 tooth ring gear? It looks just slightly different. Thanks for any help that I can get. Dennis
Art M
First Name: Art
Last Name: Mirtes
MTFCA Number: 32489
MTFCI Number: 24068
Re: 10 tooth pinion question
Post by Art M » Sun Feb 05, 2023 2:34 pm
It will probably work but would be noisy.
Art Mirtes
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Sun Feb 05, 2023 3:27 pm
Was the new pinion designed to run with Ford gears? NO
Will it? Maybe.
Will it create new fit issues with gear teeth clearance? Likely.
Will it be noisey? Maybe.
Is the metallurgy good to where a tooth wont break off? Maybe.
Back in the day, changing to a 10T pinion meant only pulling the D.S. Doing that with this gear would certainly be a problem.
You can roll the pinion on the intended ring gear. If it seems to mesh without clicking, it might work.
All the risk, hassle & potential wasted time worth it?
NO, not when a NOS ford gear is readily available here @ a fair price. NOS!!!
(I bumped it up just for you)
Dennis Prince
Last Name: Prince
MTFCA Number: 22802
Post by Dennis Prince » Sun Feb 05, 2023 5:52 pm
Thank you John, I called and am getting the one that you pointed out. Thanks again. Dennis
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Sun Feb 05, 2023 6:38 pm
Wise decision. & you cant go wrong with genuine NOS.
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Wed Feb 08, 2023 1:00 am
No one makes a "new" 42 tooth ring gear. Good luck finding a good used one.
