Wench?
Posted: Fri Feb 10, 2023 9:08 pm
by Keith Daniels
Did I get a period correct T issue wrench, or after-market deal?
Re: Wench?
Posted: Fri Feb 10, 2023 9:13 pm
by Mark Nunn
I have a drawer full of these and have no idea of what is correct. But I would suggest that you correct the spelling of your thread. It's inviting off-color remarks, like this one.
Re: Wench?
Posted: Fri Feb 10, 2023 9:25 pm
by Shannon_in_Texas
Re: Wench?
Posted: Fri Feb 10, 2023 9:28 pm
by JTT3
There are many styles but most will have Ford somewhere on them, Ford appears to be in the center of the top jaw of the one you found. I haven’t seen one like that I don’t think. Nice find though. On the attached picture you’ll see the wench on top of the Ford.
Re: Wench?
Posted: Fri Feb 10, 2023 9:33 pm
by Norman Kling
Those wrenches are good for a display, but not very good for using on the car. They tend to slip and round off the nuts or bolt heads.
Re: Wench?
Posted: Fri Feb 10, 2023 10:28 pm
by tdump
what does the end of the handle fit in? I should know but I can't think of it
Re: Wench?
Posted: Fri Feb 10, 2023 10:32 pm
by TFan
26-27 T and model A I believe, the square end is for the differential plug. Jim
Re: Wench?
Posted: Sat Feb 11, 2023 6:54 am
by Allan
Jim has it correct. The same tool with the square on the handle end, fits the 27 T differential plug, and the A model. Moore also made some of the earlier versions of this tool. The Ford script is found on many, and there were also other makers. Some had the T tool number cast in the handle or even on the fixed head of the handle. If your car is earlier than 1926, one without the square end is called for.
Re: Wench?
Posted: Sat Feb 11, 2023 8:48 am
by FreighTer Jim
While both Wench styles historically
Pre-date the Model T …
The original Wench ….
Would likely prove to be more practical
Than the later version usually found
serving Libations in Taverns
FJ
Re: Wench?
Posted: Sat Feb 11, 2023 8:51 am
by TWrenn
Ha ha Jim! Yeh, his mis-spelled word got me to look here for "something else"
Re: Wench?
Posted: Sat Feb 11, 2023 8:57 am
by FreighTer Jim
TWrenn wrote: ↑Sat Feb 11, 2023 8:51 am
Great Minds Of Debauchery Think Alike
FJ
Re: Wench?
Posted: Sat Feb 11, 2023 10:30 am
by TWrenn
Re: Wench?
Posted: Sat Feb 11, 2023 10:47 am
by Moxie26
I was led to believe that wrench was upgraded and issued for the Model A Ford to adjust the service brake at each wheel.
Re: Wench?
Posted: Sat Feb 11, 2023 11:23 am
by Original Smith
I'm sure you meant wrench. Not all 26-27's used the new style filling plug.
Re: Wench?
Posted: Sat Feb 11, 2023 3:09 pm
by 5 WoodenWheels
I’ve heard several people refer to a winch as a “wench.”
They’ll ask if I have a wench.
I have to reply, “sadly, no.”
Re: Wench?
Posted: Sat Feb 11, 2023 6:05 pm
by Keith Daniels
