Epoxy?
Posted: Mon Feb 20, 2023 10:23 pm
by kgibbo
Doing an engine rebuild and found camshaft bearings epoxied in place! Why would this have been done and any recommendations for undoing it?
Re: Epoxy?
Posted: Mon Feb 20, 2023 10:35 pm
by JTT3
With a brass drift can you tap them forward? It may require trying to chip off the epoxy then tapping to break the bound.
Re: Epoxy?
Posted: Mon Feb 20, 2023 11:01 pm
by Kevin Pharis
Try a bit of heat to release the epoxy. No doubt was attempting to cure the infamous cam bearing knock…
