Need help identifying front fender
Posted: Fri Feb 24, 2023 7:14 pm
by frank.koonce
[image][/image][image][/image]
Hello, I have a 1915 runabout that needs a right front (passenger side) fender. I have what I think is a correct left fender, with three rivets, a bill, and a flat top. A friend brought me the red fender, which also has three rivets, thinking that it was what I needed. However, as you can see in two of the attached pictures, it is wider than mine and has a bill that is shaped differently. I am thinking that the red fender may be off of a speedster or a torpedo. I would be very grateful if anyone could solve the mystery.
Re: Need help identifying front fender
Posted: Fri Feb 24, 2023 7:25 pm
by ThreePedalTapDancer
I believe the wider fender is a wide track fender for a wide track T seen here.
Posted: Fri Feb 24, 2023 7:27 pm
by Moxie26
Ed, I agree with you those wide track Fords were sold mainly in the southern states
Posted: Sat Feb 25, 2023 9:02 am
by pre15dale
Definitely wide track. I have a pair of them. I advertised them a couple years ago, there was no lnterest
Posted: Sat Feb 25, 2023 11:07 am
by George House
Yep 😜 You guys are good ! Also known as southern tread.
Posted: Sat Feb 25, 2023 3:00 pm
by speedytinc
Wide track. I might be interested in it. I have an early 15 widetrack. The fender was severely damaged @ some point in its life & has the scars on the underside to prove it. Interestingly it has 4 rivets holding the mounting bracket.
Posted: Mon Feb 27, 2023 7:03 pm
by frank.koonce
Thanks to everyone for their replies. Problem solved!
Frank
