Strobospark
Posted: Sun Mar 12, 2023 10:03 am
by BUSHMIKE
I dont want to start any discussion on its merits or lack off! I just want to come up with a set of instructions for the use and coil tuning using the Strobospark. I am only assuming that it was sold with a printed instruction sheet?
Re: Strobospark
Posted: Sun Mar 12, 2023 10:06 am
by TWrenn
Here Mike. Quick! Try this before all the controversy starts again! :lol: :lol: :lol: Feelilng a little devilish :twisted: this morning I guess! ha ha. Hope this helps.
https://www.youtube.com/watch?v=zfXVIlIO_4Q
Re: Strobospark
Posted: Sun Mar 12, 2023 10:54 am
by Chris Barker
The video is helpful, but first you need to check the capacitor:
Hold the points open, Meter set to Cap Leak, press Test - should be zero or close
Hold the points open, Meter set to Cap Value, press Test - should be 4.7, but 2 to 10 will work
Only then go to Coil Amps, medium magneto, press Test and you should get 3 single steady sparks, and about 1.3A
In summary:
Lower point root end bend affects current
Cushion point tension affects single/double spark - you need a tool https://www.modeltford.com/item/5008CST.aspx
Adjusting nut affects everything!
It's an art that you will pick up. When it works on medium magneto, check high and low.
The cushion point travel should be about 0.005" - and all 4 coils should be similar
When the coil is at rest, the lower point must push the cushion spring up off its rivet head to touch the top piece. See photo
When the lower point is held down, the cushion spring must rest against its tiny rivet head. See photo
The points gap doesn't matter, within reason, as long as you have 3 single sparks and about 1.3A (1.1A to 1.4A)
When it's right, add a locknut to the adjuster to stop you or anyone else fiddling with it!!
Re: Strobospark
Posted: Sun Mar 12, 2023 11:06 am
by BUSHMIKE
Tim,
I watched that prior to posting. The video does show a couple points, which helps. I would still love to see a set of printed instructions. It doesn’t sound like there will ever be Strobo Spark collectors group so SN 0012 is a moot point :roll: The coil that came with the unit apparently needs work!
Re: Strobospark
Posted: Sun Mar 12, 2023 11:08 am
by BUSHMIKE
Chris,
That is fantastic info!
Thank you.
Re: Strobospark
Posted: Sun Mar 12, 2023 11:49 am
by Art M
Mike,
If you cannot find a strobotach, try reading the topic in this site, A New DIY electronic coil tester. It is very interesting and informative. Let's us know your results.
Art Mirtes
Re: Strobospark
Posted: Sun Mar 12, 2023 3:46 pm
by JTT3
Copied for your reference from Funprojects aka Mr John Regan.
Re: Strobospark
Posted: Sun Mar 12, 2023 4:00 pm
Whats with page 2? Do you need a real ID to operate it?? :o :o
Edit; Page 2 of 3 was removed.
Re: Strobospark
Posted: Sun Mar 12, 2023 4:13 pm
by JTT3
John it’s what happens when you’re to cheap to buy new printer paper. Ha
Re: Strobospark
Posted: Sun Mar 12, 2023 4:54 pm
by BUSHMIKE
Many thanx John! I thought someone here would have a paper copy.
Re: Strobospark
Posted: Sun Mar 12, 2023 9:11 pm
by BE_ZERO_BE
Here is the full PDF.
STROB-O-SPARK CT-1.pdf
(1.1 MiB) Downloaded 170 times
