Identify this Steering Column if you can #1
Topic author - Posts: 8
- First Name: Tony
- Last Name: Cerovski
- * REQUIRED* Type and Year of Model Ts owned: Six 1926-7 Roadsters, One 1925 cutoff, & One-27-Coupe
- MTFCA Number: 19231
Please help identify this steering column (#1) and the vehicle it was used on.
Length of column tube is ~ 46 inches.
Spark and throttle levers are about 11 inches down the column from the steering wheel spiders.
Part number 344253 and a 4 with a (triangle K) proof mark are cast-in-place on the gearbox housing.
Thanks in advance for your help. Tony
- First Name: Tad
- Last Name: Glahn
- * REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1926 TT Closed Cab, 1924 Runabout
- MTFCA Number: 51667
Re: Identify this Steering Column if you can #1
Looks to me like late 20's Chevy four cylinder open car, like in this '25 Touring. Not my photo, pulled it from the web-ernet.
- First Name: Shannon
- Last Name: Helm
Looks like a 1925 Chevrolet?
Ha-- Tad was faster on the reply!
- First Name: Tad
- Last Name: Glahn
That rod setup is strange, I have never seen it besides your column and the photo I found. Wonder if there are any Chevy people amongst us brave enough to make themselves known and share some knowledge?
Shannon, that will probably be the only time I beat a Texan in a draw!
- Last Name: Helm
I have a Chevy frame with the steering box and column still attached and it has those levers and dash bracket and that is why I recognized them. That is about the extent of my early Chevy knowledge...
- MTFCA Number: 14383
Its destined to live again in a T speedster.
- First Name: Gerrit
- Last Name: Marks
it appears to be from some type of motorized vehicle. Can't wait for #2.
- First Name: Tad
- Last Name: Glahn
I believe Wooden Wheels hit it right on the nose.
- First Name: Tony
Thank you for the replies.
I think Tadpole and Shannon have it right, being a 1925 (+/-) Chevy Steering column. Thank you again for your replies!
5WW and Speedyt, thank you for the humor and suggestion.
PS: 5WW, I'll post the 2nd steering column in a bit. . MT5.
- First Name: Bill
- Last Name: Austen
- * REQUIRED* Type and Year of Model Ts owned: 1915
1910 Mitchell
- First Name: Bill
- Last Name: Austen
My mistake wrong place #2 is the Mitchell
