Amp meter
Posted: Fri Mar 24, 2023 10:30 am
by Barteldes
Langs doesn't have an amp meter. Mine is sticking. Is there a way to clean it? or somewhere else to get one?
Re: Amp meter
Posted: Fri Mar 24, 2023 10:32 am
by George House
What year switch/ammeter panel ?
Re: Amp meter
Posted: Fri Mar 24, 2023 10:43 am
by Barteldes
George House wrote: ↑
24 Coupe and the key and switch are worn so i assume its original. And i love your quote by the way i have two dogs I rescued as well.
Re: Amp meter
Posted: Fri Mar 24, 2023 11:23 am
by George House
So you’re needing the larger diameter ammeter that is, unfortunately, not being reproduced 😞 Go up to the top of this site to Board Index and find Classified Parts. List your need for an ammeter for a β€˜24 coupe. You’ll get responses there 😁
Re: Amp meter
Posted: Fri Mar 24, 2023 11:29 am
by TRDxB2
Barteldes wrote: ↑
The internal movement is a rather delicate mechanism. The question is why is it sticking.
I have some of the large ammeters. email sent
Re: Amp meter
Posted: Fri Mar 24, 2023 1:52 pm
by John kuehn
Seems like the supplier who makes the Magneto meter could make an Amp meter. HMMMM
Re: Amp meter
Posted: Fri Mar 24, 2023 2:52 pm
by TRDxB2
John kuehn wrote: ↑
The supplier that made the Magneto Meter was the same that made the large ammeters - Fun Projects. Now owned by Birdhaven :roll:
Re: Amp meter
Posted: Fri Mar 24, 2023 3:17 pm
by Been Here Before
A 20-0-20 ampere meter can be found on early tractors. Ever think about looking at those who enjoy old tractors?
Re: Amp meter
Posted: Fri Mar 24, 2023 8:43 pm
by J1MGOLDEN
If you need an ammeter, you probably need the switch and other parts as well!
The most likely part to be bad is the cylinder the key turns.
That part is usually broken on the top or bottom of the key slot.
They are not being manufactured now.
Re: Amp meter
Posted: Fri Mar 24, 2023 9:29 pm
by Mike Howell
Bill, my T has an ammeter that I believe is like yours. When it gets sticky, I remove the back of it and spray it real good with starting fluid. Let it dry, reassemble, and it's good for another 5 or 6 years. Electronic parts cleaner would probably work also, but I never seem to have any around.
Re: Amp meter
Posted: Thu Mar 30, 2023 10:47 am
by Barteldes
Mike Howell wrote: ↑
oh great . thanks!
Re: Amp meter
Posted: Thu Mar 30, 2023 12:30 pm
by Craig Leach
The old tractor guys may be Steiner. SteinerTractor.com 1-800-234-3280 the one pictured is for a 2" hole Order # ABC016 for Ford tractors
1939-57 but sold for most with a 2" meter. For a few dallars more you can get one with favorit tractor logo.
Re: Amp meter
Posted: Thu Mar 30, 2023 11:18 pm
by DHort
Did you try Snyders, Chaffins, Bob's, and Gaslight Auto?
