GPS Speedometer ? ? ?
Topic author - Posts: 66
- First Name: Roger
- Last Name: Byrne
- * REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo Open Runabout, 1914 Touring, 1912 Speedster (in progress) 1927 Touring
- MTFCA Number: 8127
Is anyone using a GPS speedometer on their Model T? How is it working out and do the coils cause a problem?
Preserving Mechanical History for Future Generations since 1965
- Last Name: Dufault
- MTFCA Number: 303
Re: GPS Speedometer ? ? ?
Yes, I use an inexpensive Garmin for route and speed info. No coil problems.
Dave
Dave
- Last Name: Nunn
- MTFCA Number: 50321
I use Ulysse speedometer app on my phone. I use it in the Model T, skiing, in the plane, etc. It works great.
- MTFCA Number: 14383
- First Name: Roger
- Last Name: Byrne
Thanks for the comments but I'm not talking about a phone app. I'm wondering about the GPS units that look like a speedometer used on boats and ATVs.
- Attachments
- 0019213_vintage-3-38-low-speed-speedometer_300.jpg (23.55 KiB) Viewed 1026 times
But Roger, that only goes to 60mph.
- Last Name: Kelly
I use an app. called Speed Bot on my cell phone. Gives the same info a Garmin does. Works good.
- First Name: Art
- Last Name: Mirtes
- MTFCA Number: 32489
- MTFCI Number: 24068
I use a Garmin GPS any time I am driving. Previous units would not work on 6 volt, so i used 2 6 volt rechargeable hunting batteries connected in aeries. The current unit works very well plugged into my 6 volt car. Even starting the engine presents no problem to the Garmin.
Speed is observed and distance is recorded on each trip. A friend, whom I often tour with, also uses a Garmin connected to the car 6 volt circuit.
Art Mirtes
Art Mirtes
- MTFCA Number: 16175
- MTFCI Number: 14758
I have used a Garmin and a Navpal and a bicycle speedometer, and had no coil interference with any of them. BUT I am installing a real Model T era speedometer because it has a mechanical odometer that will never need a battery change that wipes out the accumulated mileage.
I was going to look into this awhile ago - might work with a period correct speedometer. The only issues may be matching up a speedometer cable and 12v.Roger Byrne wrote: ↑Sat Mar 25, 2023 8:02 pmThanks for the comments but I'm not talking about a phone app. I'm wondering about the GPS units that look like a speedometer used on boats and ATVs.
https://speedhut.com/categories/speedbox.html
Instructions https://speedhut.com/content/instructio ... -10-16.pdf
- Last Name: Monticciolo
- * REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
- MTFCA Number: 21108
I have a marine GPS speedometer from Cabelas approx $90.00. It is a 12v unit, just power & ground to install. Running with dist ignition, no issues.
Oscoda Michigan
JohnOscoda Michigan
- First Name: Roger
- Last Name: Byrne
Thanks John, that was the type of installation I am interested in! By the way Dan, they make them in a 120MPH version so it could work for guys like you too!
