rocky mountain brakes
Barteldes
First Name: Bill
Last Name: Barteldes
* REQUIRED* Type and Year of Model Ts owned: 1924 Coup
Post by Barteldes » Tue Mar 28, 2023 5:17 pm
I have a 24 coupe and think i should get the rocky mountain brakes. I dont care if i die but it would be a shame to hurt that Beautiful car. Where do i start? Langs? Are they hard to install? And is it better to get the petal rather than welding on a tab yourself?
BIll B
No matter how you shake and dance the last few drops go down your pants.
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Re: rocky mountain brakes
Post by speedytinc » Tue Mar 28, 2023 5:32 pm
Agree, you can mend, the car cant be put back the same. :D
You can buy them directly. Vintage Ford has an advertisement.
Easy to install, but expect some clearance issues. Most folks add axle shims. I hate that. Changing to longer axles makes for a much bigger job.
I have always welded my own pedal extension. Until fairly recently, new pedals with cams were not available.(in old man years)
If you go with a new pedal, check for casting flaws on the cam before you install. (learned the hard way once)
Barteldes
First Name: Bill
Post by Barteldes » Tue Mar 28, 2023 5:35 pm
Thanks John! good stuff
BIll B
Barteldes
First Name: Bill
Post by Barteldes » Wed Mar 29, 2023 3:09 pm
it doesnt look like vintage Ford has them. Langs has them for $1120.00 is that a good price?
BIll B
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Wed Mar 29, 2023 6:28 pm
Do you realize "Vintage Ford" is our Club magazine ? Bud runs an ad in the Vintage Ford for his brakes.
Last Name: Hjortnaes
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Thu Mar 30, 2023 1:22 am
I bought mine a few years ago. Guess I paid about $900 for them.
Some day they might get put on the car.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Thu Mar 30, 2023 11:51 am
The problem with reproduction parts is they don't always reproduce the part correctly. The same goes with the current Rocky Mountain Brakes.
If they were made the way they were made originally, there wouldn't be a need for axle shims. The original drums used a standard brake drum, with the Rocky Mountain drum riveted to it, therefor no need for shims!
Post by Norman Kling » Thu Mar 30, 2023 11:54 am
Original, Can you post a picture of the "Original" Rocky Mountain Brake? I am not familiar with it at all. One I am familiar with is called AC which looks and works just like the current Rocky Mountain Brake.
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Thu Mar 30, 2023 12:03 pm
I have RM's on all three of my cars and none have shims. Sounds like some other issue brings up the need. You can install the RM's in an afternoon easily, then takes a few short trips "in and out" to tweak the set up. You want them doing 90% of the work and the last 10% on the trans. brake drum.
Post by Norman Kling » Thu Mar 30, 2023 12:10 pm
If you have 26-27 rear axle with the larger factory drums, you don't need shims. If you have the earlier rear axle with the small drums, the currently manufactured Rocky Mountain brakes use a larger drum bolted between the hub and the original drum. This moves the inner drum closer to the backing plate and usually you will need either shims or longer axle shafts.
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Thu Mar 30, 2023 1:58 pm
Tim
What do you do different that others need shims and you do not?
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Thu Mar 30, 2023 4:05 pm
The knock on Rockies is that they don't work backing up. Just backing the car into the shop, that's not a big deal. But I can imagine being on a mountain road in a Model T that wants to roll backwards. Plunging off a thousand-foot cliff could be pretty disappointing.
I plan to install AC brakes, which are said to work in both directions. They also sell for about half the price of Rockies.
Post by Norman Kling » Thu Mar 30, 2023 4:19 pm
When backing up, you usually are going slowly. Also if you kill the car on a hill, it stops. If you have the original band in the transmission and you adjust the brakes so that a hard push applies both the rocky and the original Ford brake, it will hold, also adjust the parking brake so it comes on first when you pull back the lever. So you have two ways to hold the car from rolling backward. I live in the mountains and have no problems. Only one I know who had such a problem bought a car from which the original Ford band had been removed. He did not know that because he had recently bought the car. When it killed going up a steep hill he found out when he rolled back.
Barteldes
First Name: Bill
Post by Barteldes » Thu Mar 30, 2023 5:12 pm
no i didnt ..lmao i googled it and found a company in Cali that sells model t parts.. so Bud sells them lol that's clever.
BIll B
Barteldes
First Name: Bill
Post by Barteldes » Thu Mar 30, 2023 5:15 pm
langs has different mods for different years. the later years are really cheap and of course mine are the most expensive.
BIll B
Barteldes
First Name: Bill
Post by Barteldes » Thu Mar 30, 2023 5:20 pm
Flawlessly logical. so who sells the AC's ?
BIll B
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Thu Mar 30, 2023 6:05 pm
Tim
I didn't do anything as the first 2 cars came with them, I put them on my '25 Fordor, and I suspect they all have the longer axle shafts.
hull 433
First Name: Stan
Last Name: Gadson
Post by hull 433 » Thu Mar 30, 2023 10:04 pm
Here are some original Rockies, from Original's car. Saw it at a tour last Friday. Nice looking castings.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Fri Mar 31, 2023 12:29 am
...so who sells the AC's ?
See Larry Sidmore's ad in The Vintage Ford. Rich Baughman sells the linkages.
Nv Bob
First Name: Bob
Last Name: Middleton
Post by Nv Bob » Fri Mar 31, 2023 2:24 am
The new rockies are redesigned from the orginal design in that there's an increase in forward braking
And loose some backward braking
The orginals are happy mix in both direction
That being said only time I cursed new rockies on mountai road and had stop and I had stand on the pedal and still rolled back into the hillside
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Post by Oldav8tor » Fri Mar 31, 2023 6:43 am
My disc brakes work the same, forward or backwards, wet or dry....just sayin'.... :D
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Fri Mar 31, 2023 11:30 am
The photos above are on my 1913 runabout. Thanks for posting! They are 100% original Rocky Mountain Brakes.
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Fri Mar 31, 2023 11:43 am
I restored a set once.
They will equally lock the wheels up in forward AND reverse.
J1MGOLDEN
Last Name: Golden
MTFCA Number: 14294
MTFCI Number: 13562
Post by J1MGOLDEN » Fri Mar 31, 2023 1:13 pm
Do they also work better when wet?
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Fri Mar 31, 2023 1:17 pm
No external brake material works good when wet - I always "ride the brake" to produce heat to assist in drying out the lining !
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Fri Mar 31, 2023 1:27 pm
Definitely NOT.
A sudden down pour or stream crossing can lose ALL of their braking ability until dried out again.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Fri Mar 31, 2023 2:26 pm
I asked about Rockies and reverse at last night's club meeting. I gather that the problem is with the modern version, not the originals.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Fri Mar 31, 2023 2:39 pm
The different braking power in reverse vs. forward is caused by the location of the brake band anchor point. The Rockies currently available from the vendors have the anchor point near one end to maximize the self-energizing effect while going forward. The original and earlier reproduction Rockies had the anchor point in the middle of the band, giving the same self-energizing power in forward and reverse.
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Fri Mar 31, 2023 7:44 pm
Steve
Richard Baughman has medical issues and is no longer making any linkages. I wish he was.
Dave
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sat Apr 01, 2023 11:32 am
I have those instructions too. I believe there is a page 2 for them also, but haven't seen a page 2. You might notice the cams on the bands for adjusting the alignment of the band. The first series brakes did not have this, and would have to be added to be 100% correct. The first series I'm referring to was made before the current offering, and as I mentioned Jack was not mechanically inclined, and probably didn't know what they were for!
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sat Apr 01, 2023 11:35 am
I had some of the springs reproduced recently for the original brakes, and am willing to sell them for $10 each.
