Why Can I Not Post Photos?
Topic author - Posts: 878
- First Name: Bruce
- Last Name: Brakke
- MTFCA Number: 31192
Why can't I post photos that are taken with my phone in vertical position?
- First Name: Kevin
- Last Name: Pharis
Re: Why Can I Not Post Photos?
I agree it’s annoying… but the pixel size restrictions favor landscape pics. Simply rotate rod pics and they should load… or reduce the resolution in your settings
- MTFCA Number: 16175
- MTFCI Number: 14758
When I started seeing the "landscape" and "portrait" designations in recent years I was mystified, but eventually figured out they mean horizontal and vertical. (When did we adopt the British term roundabout for traffic circles? And start saying "graduate high school" and "year anniversary"?)
Anyway, when I have a vertical photo show up turned horizontal I go back to the original and rotate it 90º left, then back 90º right (or vice versa) and it posts correctly. I have no idea why this works, but it does.
First: The software that the Forum restrict you to a maximum upload file size prior to converting it for efficient storage. Don't know what that is
I tried a few methods
The first was to select the file directly from my iPhone that got the yellow triangle (note the image appears upright ion the phone - but sideways in the file folder - that has nothing to do with the issue
--Next was to copy-n'paste from the iPhone to my lap top and the select it without resizing - the file was relative large but was loaded successfully
--The image size is displayed by right clicking on the photo. Notice the significant reduction.
--Lastly the space around the photo would suggest that a large rectangular image could be displayed.
Not sure if the small difference in file size between is iphone & copied file would have caused the yellow triangle or something else (think that was discussed before). So it may not always be necessary to reduce the size
This shows the file size on the iPhone --
This shows the file size on the laptop from copy-n'past that I loaded without issue --
This is the image uploaded from the laptop without any resizing prior to the uplaoad. The size shown was done by the software conversion --
- MTFCA Number: 24868
The glass is half full...
In the spirit of a forum discussion....
No it looks more like its half empty.
- First Name: Kevin
- Last Name: Pharis
From my angle… it looks like the glass is too big
- MTFCA Number: 14383
No, its neither 1/2 full or 1/2 empty. Its 45% empty.
It's that kind of thinking that almost ruined this country!
Actually, that's thinking like an engineer
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
That is not even water. It is Kerosene.
Since humans are 60% water, it is obvious that if there was just a little more in that glass, you'd need to put diapers on it.
NH Full Flow Float Valves
I wouldn't even know whether or not you can load directly from your phone. However all my pictures are loaded into the computer under My Pictures. Whether or not they came from a phone or from someone else's e-mail. My wife does Facebook and she sometimes loads the pictures to MY pictures. I take them from My pictures directly to the forum. Then I preview them If they come out the way I want, I then submit. If not, I resize or rotate on photo shop and then preview them again. If I like what I see, I submit. A little work, however, almost all pictures are fine just as I have them in My pictures without any changes.
