‘26 Touring Top Bows
Carl
First Name: Carl
Last Name: Sorenson
Post by Carl » Thu Mar 30, 2023 3:02 pm
On my ‘26 Touring the top bows ,that fit into the irons , have a “tenon” cut on them …
Does anyone have the length ,between tenons on all four bows ..I’m most concerned about the #1 & #4 bows …
The ones on them right now ,,look original ….But are different than the ones in the kit I got with the car …
They are from the Gentleman that produced them in Northern Calif……
Thanks in advance …Carl…
Last Name: Humble
* REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
MTFCA Number: 28034
Board Member Since: 2006
Re: ‘26 Touring Top Bows
Post by Humblej » Thu Mar 30, 2023 4:51 pm
Determine the length of the #1 bow by using the windshield stantion clamps to set the correct length. You can use the #1 bow length for all the other bow lengths. When the top is folded all the bows should line up on the saddle.
Mustang1964s
Last Name: Bourgeois
* REQUIRED* Type and Year of Model Ts owned: 1914, 1926
MTFCA Number: 29784
MTFCI Number: 22970
Post by Mustang1964s » Fri Mar 31, 2023 3:46 pm
Are the Top Bows different on the '26 than on the '27?
The length between the first and second are different. It seems that the last is a little shorter than the third.
