Spring Rate of Watts Spring vs. Stock Ford?
Posted: Fri Mar 31, 2023 10:40 am
by CudaMan
Does anyone know and can share just how much stiffer the special round wire Watts clutch spring is over the stock Ford flat wound spring?
Re: Spring Rate of Watts Spring vs. Stock Ford?
Posted: Fri Mar 31, 2023 11:01 am
I've not used a spring compressor scale to verify but the wound round Watts is/was considerably stronger than an original. The new springs are around 100 lbs. +. I've removed a couple Watts springs from transmissions that had the clutch throw-out collar stubs nearly worn through from so much spring pressure.
Posted: Fri Mar 31, 2023 11:17 am
by Adam
It has been several years since I tested a reproduction spring, but they always used to be 135# at 2”. The watts spring is heavier than that. Good used original springs are 95 to 105 pounds.
The Ford engine and transmission is engineered for about a 100# clutch spring. Any stronger spring than that and you will have accelerated wear issues in other areas.
Posted: Fri Mar 31, 2023 11:29 am
The problem with the watts clutch is the fewer number of disks.
Not enough clutch surface, so to compensate it requires a stronger spring.
Not the most successful "improvement" for a model T.
Good luck.
Posted: Fri Mar 31, 2023 11:50 am
by Craig Leach
Hi Mark,
I have recently installed a Watts clutch in my speedster. I was lucky enough to find a new one with the round spring & one with the square
spring. The round one was 122# @ 2" the square sping was 114# a used round spring I picked up was 108#. The instructions say you will/may
need to adjust as it wears in, I have done this twice and found a little axtra preassure will still leave a free nuetral @ 15/16"-1" and gives a
very smooth & positive engagement. ( I can push the car out of the garage with one hand )
Craig.
Posted: Fri Mar 31, 2023 12:06 pm
As I recall, The Watts round spring can/did expand on the throw out sleeve & cock out of place.
Later versions added a "cup" to retain the spring.
Posted: Fri Mar 31, 2023 12:42 pm
by Craig Leach
Hi John,
If you find that info please share it OK. Thanks.
Craig.
Posted: Fri Mar 31, 2023 1:10 pm
by CudaMan
Great input guys, thanks!
I have an original set of Watts clutch disks on the shelf, but no spring.
Posted: Fri Mar 31, 2023 1:23 pm
Judging by the spring rates provided, a new higher tension square spring would work fine
with possibly a little extra tension via the 3 finger adjustment.
Do check the new springs tension. I have found a wide range from 110#'s to 130#'s
The stiffer tension preferred for the Watts disks.
