1925 roadster roof install question
Topic author - Posts: 9
- First Name: Colin
- Last Name: Knowles
- * REQUIRED* Type and Year of Model Ts owned: 1920 Pickup, 1924 Touring,1926 Roadster pickup 1927 TT
- MTFCA Number: 21199
- MTFCI Number: 19189
Installing the roof covering kit. Not sure how the front flap is to be installed at the corners. Do I cut it? Pictures anyone?
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
Re: 1925 roadster roof install question
http://www.mtfca.com/discus/messages/50 ... 1449522321
http://www.mtfca.com/discus/messages/82 ... 1521040014
- MTFCA Number: 1219
I'm not sure if this helps. It is a Dan trace photo from this 1915 discussion but looks like a '23-'25 front flap.
http://www.mtfca.com/discus/messages/82 ... 1535333350
Colin, I am not familiar with how the flap sits on US Ford cars, so I may be wrong in this suggestion, but it did work most succesfully on my 1915 tourer.
The flap does not hang down at the front and it does not need cutting to length if you fit it in the following manner. Lay the flap, on the flat, on the under side of the bow. lift the ends up to the bow and nail/staple them down to the top surface of the bow first. Then go across the front in the same manner. That will leave you with some gathering/puckering to do at the corners, which will be covered by the binding when you finish it off. Then you trim off any excess which protrudes above the row of staples.
In service, the flap is held tightly forward by the windscreen, with the corners holding tension on it so it does not flap around.
It worked for me, and 27 years on is still working. It may not be as effective on later cars, depending on how far forward of the windscreen the front bow sits.
Hope this helps.
Hope this helps.
- MTFCA Number: 121
- MTFCI Number: 16310
The photo you posted above is not correct. Should you need the correct information, I'll be happy to help.
- First Name: Jim, Sr.
- Last Name: Rodell
- * REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
- MTFCA Number: 2406
- MTFCI Number: 22213
Here are some photos of the wind flap on a 1924 Touring that has the original top and upholstery. I have more photos of the details if you need them.
1922 Coupe , 1926 Touring
Jim, your photos confirm my suspicion that what I was posting may not apply to later cars with the front bow set well past the windscreen. It is just like it is done on our Colonial tops.
- First Name: Colin
Thank you for the pictures and info. I think I can get it from here on. Not sure why the piece is made about 8-10 inches longer on each end and sewn. It's a big rectangle that is too thick to roll into place anywhere and the instructions are very vague.
Colin, I am not quite sure what you're having difficulty with (other than it's a pretty involved job to do on your own with no previous experience). Take a look at these and see if you can get tips here:
https://modeltfordfix.com/installing-a- ... r-model-t/
or here:
http://www.mtfca.com/discus/messages/33 ... 1379253208
or here:
NH Full Flow Float Valves
- First Name: Colin
Scott, The problem is the front "windscreen" is about 16inches too long compared to the pictures I have seen anywhere. It is cut square on the ends and sewn nicely. Just seemed strange that it would need to be cut down that much. It is similar to the one in the second post you mention but the instructions show it not being wrapped up around the front bow but rather tacked to the front and under. There is way to much material the way it is to ever nail it in place and look correct. Not my first top install, but my first 25 top install.
Oh, OK. Sorry the posts were not helpful. I've never done a later top, though have seen the finished product, of course. I am wondering if you could simply contact the folks who made the kit...I am wondering if one side wasn't finished off simply to keep the material in good order for packing or if it was simply done in error. I am sorry that I cannot offer any definitive info on how to proceed. This is an area where I have little experience. Best of luck cyphering this out.
