Need Input
Posted: Sat Jan 12, 2019 9:39 pm
I'm getting ready to put the engine back in my '17 touring and have a question. In sealing the coupling ring that holds the ball around the universal joint to the engine do you recommend:
1- The paper gasket installed dry
2- The paper gasket coated with grease
3- The Paper gasket installed with permatex 2
4- The paper gasket installed with ultra black or the like
5- No paper gasket - ultra black only.
• Other.....
With the ball free to move in the coupling I'm sure that a perfect seal is impossible. I know I'm dreaming but I actually hope to greatly reduce leakage from the engine and drive train
• Other.....
