				Lower radiator shell screw size
				Posted: Mon Apr 17, 2023 8:11 pm
				by Plankhill
				What is the screw size for the screw that holds the lower radiator apron to the front motor mount on a 26-27?
				Re: Lower radiator shell screw size
				Posted: Mon Apr 17, 2023 9:31 pm
				by Moxie26
				I believe it's the same screw size and design that holds the inspection door on the transmission
				Posted: Tue Apr 18, 2023 3:33 pm
				That button head machine screw for the '26-'27 radiator apron with the 3075D spring clip/motor mount with the threaded hole is Fac. # T-8004.   The size is 1/4 x 20 x 3/8" long.  Some times a washer is needed under the screw if the hole in the apron is worn larger.
The hogshead cover door screw is also button head, but larger,  as it's 5/16" x 18 x 3/8"
				Posted: Tue Apr 18, 2023 11:20 pm
				by Moxie26
				Thanks for the clarification Dan, appreciated.
				Posted: Thu Apr 20, 2023 1:13 pm
				by SurfCityGene
				Just did one yesterday and looked like 1/4 - 20TPI
