How Can You Tell If Oil has Graphite in it?
Bill Everett
First Name: Bill
Last Name: Everett
MTFCA Number: 93
Board Member Since: 2011
Post by Bill Everett » Thu May 09, 2019 2:22 pm
A common them in oil posts is to not use oil with graphite in it.
How can you tell if the oil you're thinking of using DOES have graphite in it?
Philip
First Name: Philip
Last Name: Thompson
Re: How Can You Tell If Oil has Graphite in it?
Post by Philip » Thu May 09, 2019 2:31 pm
im pretty sure if you stick with normal 10w30 valvolene penzoil ect you are good
Post by Scott_Conger » Thu May 09, 2019 2:32 pm
It would be black as the ace of spades, and stain your hands. ARCO graphite oil is the only one I can recall in my life and that's gone from the market as far as I know. You'd have to specifically add it via an oil additive, which IS available...so the easy choice is: don't
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Thu May 09, 2019 2:51 pm
Fairly safe your motor oil choices wouldn't have graphite.
But beware of greases, esp. if you use graphite containing greases in the u-joint. Could get mixed with the engine oil, maybe such small qty. that wouldn't hurt the magneto, but why chance? :?
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Thu May 09, 2019 9:45 pm
Read the label!
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Thu May 09, 2019 10:12 pm
Any recent API certified oil will not have graphite in it.
