Any suggestions for Spencer Fatman steering wheel removal?
Posted: Tue Apr 25, 2023 9:24 am
by ModelTSpeedster
I recently picked this up and need to know the secret for removing it from the steering column. The wheel spins freely, so the lock is not engaged. Is the key required to remove the center cover in order to get to the retaining nut?
Re: Any suggestions for Spencer Fatman steering wheel removal?
Posted: Wed Apr 26, 2023 8:03 am
by ModelTSpeedster
Any ideas?
Posted: Wed Apr 26, 2023 8:27 am
Look in that cover cap hole. I expect that plug must be pulled to access the nut.
The question would be is there also a pin or 2 retaining it also.
Posted: Wed Apr 26, 2023 9:07 am
by Mark Nunn
Look at the patent drawing for patent 1,596,230. It may help to see what's inside the mechanism.
Posted: Wed Apr 26, 2023 9:15 am
by Ratfink56
Someone put a washer in the center instead of a cap. Pry off the washer and the nut is underneath. It will then come off.
Posted: Wed Apr 26, 2023 12:12 pm
by ModelTSpeedster
Thanks for the replies and advice. I will try to pry the center plug out.
Mark, where did you find the patent info? I haven't had any luck searching.
Posted: Wed Apr 26, 2023 12:39 pm
Good info on the wheel https://www.worthpoint.com/worthopedia/ ... -406140865
"With the pawl engaged, the wheel operates normally. With the pawl retracted, the steering wheel spins without turning the steering shaft or the front wheels, making the car impossible to drive (and harder to steal.) "
Picture of the key
spenser fatman keys.jpg (31.75 KiB) Viewed 3698 times
Whats under the center plate. Horn contacts?
https://www.mtfca.com/discus/messages/1 ... 1267560735
https://fountainheadauto.blogspot.com/2 ... wheel.html
Posted: Wed Apr 26, 2023 12:49 pm
by Mark Nunn
Posted: Wed Apr 26, 2023 3:39 pm
by ModelTSpeedster
Many thanks for your help! I will report back to you when I get it removed from the column.
Posted: Wed Apr 26, 2023 5:10 pm
by Harry Lillo
I had a look at two different Spencer Fatman wheels that I have here.
Both have the flat disc with the hole in the centre. I believe it
is part of the design of the wheel. If Spencer made the wheel to freewheel
through the key, I doubt they would allow the security to be defeated by prying off
a small plate. Sorry I can't answer your original question.
Harry
Posted: Wed Apr 26, 2023 7:02 pm
by ModelTSpeedster
Judging from the pictures and the description with the patent information that Mark provided, my best option is to get a key from the Chicago Lock folks and use it to (ultimately) release the cover plate and get to the nut holding it to the column. I have found several possible sources of keys that match the number on this wheel.
I am trying my best not to butcher it. The steering column is the later style that I would like to use on my Faultless speedster project.
Thank you all again for your ideas.
Posted: Thu Apr 27, 2023 12:14 am
by TFan
Randy, If you can get the number off of the face of the tumbler a good old time locksmith should be able to make you a new key, I have done this several times with gumball machines and one locking T steering wheel. Hard to see in the pic but this particular one is #2007. Jim
Posted: Thu Apr 27, 2023 9:25 am
by ModelTSpeedster
The Chicago Lock Company key is #2092 and should be fairly simple to obtain.
Posted: Thu Apr 27, 2023 7:59 pm
by modeltspaz
I know that it's been discussed before, but the best bet when it comes to searching for a knowledgeable person that may not only have a catalog listing Chicago Lock Company serial numbers and codes, but he may have the correct key in stock is, none other than the Mercury Speedster king, Jarvis Erickson.
His main deal is vintage locks and keys. I don't have his info handy, but I believe he lives somewhere in the Pacific North West. I'm sure someone on this forum has his contact info, or you can do a search on his name.
Best of luck.
Posted: Thu Apr 27, 2023 8:31 pm
If the code is no longer available for this lock (I'll bet it's available), then any locksmith worth their salt (and a lot of amateur's, too) will pick this in 60 seconds (or less).
There really doesn't need to be a whole lot of drama over this.
Update: Spencer Fatman steering wheel removal
Posted: Mon May 01, 2023 3:15 pm
by ModelTSpeedster
Update on the Spencer wheel:
I was able to purchase replacement keys from a company called easykeys and they are a perfect fit. However, they did not make any difference in removing the steering wheel.
Since the horn button is no longer present, I tapped a threaded hole in its place and the center cover came out very easily. A retainer clip surrounding the steering case nut was easy to remove and the the steering wheel was as well.
Posted: Mon May 01, 2023 3:17 pm
by ModelTSpeedster
On another note, on cleanup, I found the name of a previous owner inscribed on one of the spokes, Fred Robert Falck of Lignite, North Dakota. A quick search shows that likely family members still reside in Lignite.
