Anyone running LED Headlights?
Posted: Thu May 04, 2023 10:07 pm
by Model T Ron
So is anyone running LED Headlights? If so can you give the model information and a little review for us guys without them?
Ron
Re: Anyone running LED Headlights?
Posted: Thu May 04, 2023 10:24 pm
by JTT3
Posted: Thu May 04, 2023 11:08 pm
by DaveBarker
I'm running them on my 1919 racer; both headlights and the tailight. Put them in last August. All good.
Here's a link to the ones I got. A little pricey, but I like being seen when necessary:
https://www.logolites.com/products/led- ... eadlights/
Posted: Fri May 05, 2023 2:48 am
by JohnH
I've been using them for about the last seven years. Very happy with their performance. The ones I'm using are 6V with high and low beam. They were obtained from
http://www.classicandvintagebulbs.com/
I also replaced the reflectors which probably made more of a noticeable difference than changing to LED bulbs alone.
- DSCF2926a.jpg (30.76 KiB) Viewed 1877 times
Posted: Fri May 05, 2023 3:07 am
by Craig Leach
I'm one of those darn 12 Volt people and have good reflectors so my lights are very good, but the first bulb that burns out I'm going to LED's
they are far suppirior to the regular ones.
Craig.
Posted: Fri May 05, 2023 10:10 am
by Oldav8tor
I run 12 volt LED Headlights, tail lights, side lights. Very happy with all. My headlights are single beam and give plenty of illumination for the speeds I drive.
Posted: Fri May 05, 2023 10:46 am
by KWTownsend
None of my cars have generators. I rewired for LED bulbs to run off the battery, now I have constant brilliant light while drawing a fraction of an Amp.
I love 'em!
Posted: Fri May 05, 2023 6:35 pm
by Oldav8tor
To build on what Keith wrote - I don't have a generator either. My Odyssey battery rides under the back seat and is kept charged by a John Regan Hot Shot charger that uses the magneto to charge the battery (AC to pulsating DC.) The LED's don't draw much current and the Hot Shot keeps the battery fully charged.
