Help on wiring please.
Posted: Fri May 12, 2023 5:50 pm
by jaybee47
Does anyone know where I can get a wiring diagram for a 12 volt system having an alternator, distributor, starter, coil, lighting, etc.?
It is a mutt 1911 Model T Runabout. The previous owner had installed the alternator, starter, lights, distributor and coil...all 12 volts...but no wiring...this is what I need help on. Am not good at electrical wiring on the fly without seeing a diagram compatible with this setup. I need a visual guide.
Re: Help on wiring please.
Posted: Fri May 12, 2023 6:42 pm
by TRDxB2
19-25WiringDiagramwDist.pdf
(2 MiB) Downloaded 63 times
26-27WiringDiagramwDist.pdf
(2.13 MiB) Downloaded 58 times
NOTE Not all ignition coils require a ballast resistor. You need to check its instructions
Posted: Fri May 12, 2023 7:28 pm
by jsaylor
One more note. When on 12 volts, the ignition coil will need a ballast resistor in series with the supply voltage. Some 12 volt coils have this built in some do not. Check your coil, hopefully its marked. If you need a ballast resistor look for Napa part number ECH ICR12 --$7.69. I have also used this same resistor to run a 6 volt horn on 12 volts.
Posted: Sat May 13, 2023 11:31 am
by jaybee47
Just what I needed....many many thanks to Frank and John :D :D
