I’m checking the alignment of my firewall to cowl support mounting holes to the cowl itself. Eventually a piece of gasket if will go under the cowl support wood.
This is for my 22 Centerdoor. Some of the support wood is original. Other parts are a kit from a different style of car, since no cowl wood is made for this car.
Locating mounting holes.
Topic author - Posts: 811
- First Name: William
- Last Name: Vanderburg
- MTFCA Number: 28382
- First Name: Ken
- Last Name: Buhler
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster 1927 Coupe
- MTFCA Number: 49471
- Board Member Since: 2012
Re: Locating mounting holes.
Brackets are intended to hold parts that are already mated , not as a starting point to build from.
Work honestly
Stay true to your word
Get the job done right
I’m not building anything. I’m just making sure my mounting holes are aligned. The car will be assembled in a specific order on its frame. I do not have anyplace to build a body on a flat floor, and then raise that body into place.Ken Buhler wrote: ↑Sat May 27, 2023 11:09 amBrackets are intended to hold parts that are already mated , not as a starting point to build from.
William L Vanderburg
1922 Center Door Sedan
