Starting no-start diagnosis
Topic author - Posts: 178
- First Name: Gerrit
- Last Name: Marks
Howdy from Maryland1
Beautiful tour today, just outstanding. Sixty-some miles through the countryside. At one of the stops I lost my electric start. We got the car going again with the help of another club member crank-starting.
No sound at all when I step on the starter switch. No spinning starter shaft, no clunk. Nothing. I thought, ok, I'll just jump the two terminals with a robust jumper when I got home. Just produced a healthy spark. Nothing from the starter. Kinda surprised. I thought even with a bad switch, this would produce something along the lines of a car that wanted to start.
Any suggestions? To end on a positive note, this marks the first day I hand-cranked my car to start. Several times, in fact. Very proud of that fact. The first one was courtesy of a club member, then I was all on my lonesome after that.
Thanks in advance for any thoughts on this situation.
Gerrit
Gerrit
- MTFCA Number: 51486
Re: Starting no-start diagnosis
The terminal post on the starter may be loose at the internal connection inside the starter. That condition can make a poor connection or no connection between the starter and battery, even if the switch, battery, ground(s) and all cable connections are clean and tight and the battery is good and fully charged.
I'd check ALL connections in the starter circuit and be sure that the battery itself is in good condition and fully charged.
Another possibility is stuck or worn brushes inside the starter.
Oil inside the starter motor can cause problems.
- Last Name: Marks
Thank you. I'm confident the battery is good, will check things over tomorrow when I have a bit more time. I'll report back with any findings.TXGOAT2 wrote: ↑Sun May 28, 2023 9:47 pmThe terminal post on the starter may be loose at the internal connection inside the starter. That condition can make a poor connection or no connection between the starter and battery, even if the switch, battery, ground(s) and all cable connections are clean and tight and the battery is good and fully charged.
Gerrit
- MTFCA Number: 28924
Sounds like you have a starting circuit issue. When you connected the jumper cables at the starter switch and had a good spark but was the circuit completed? To complete the circuit you would need to actually press the starter switch. If it’s an original switch the copper contacts inside it may be burnt enough to not have any contact after it’s pressed. And as stated above the issue could be the starter itself.
Check for a good ground , loose wires and etc. Good luck.
Adding to what other said.
If you only jumped across the posts on the switch & nothing. Did you try check the wiring from the switch to the starter or even tried to jump directly to the starter?
Doubt if its the switch based on jumping across the posts and getting a spark
Repo starter switches are similar to the original switches . Repro switches need to be positioned correctly or else they will eventually fail
One style --
Another style repro switch that can fail when the plunger is to high above the floor board
One style --
- Attachments
- sw2.jpg (66.87 KiB) Viewed 779 times
- Last Name: Golden
- MTFCA Number: 14294
- MTFCI Number: 13562
A common problem is caused by tightening the starter terminal nut too tight and breaking the connection to the field coils.
An easy check is to measure the resistance with an ohm meter between that terminal and the starter case.
That should be a single digit number if the connection is good.
- Last Name: C
- MTFCA Number: 52098
This will show what Pat & James are referring to about the starter post contact.
- Attachments
- Repairing a Common Model T Starter Problem.pdf
- (958.95 KiB) Downloaded 40 times
Socialism is resentment disguised as compassion enforced by tyranny disguised as tolerance.
- Last Name: Yuill
- * REQUIRED* Type and Year of Model Ts owned: 1926 coupe
- Board Member Since: 2023
I had a similar experience that baffled me. My starter button was getting hung up the the hole in the floorboard and not plunging down far enough to make contact. I had an extension on the button to elevate it above the floor..simple fix.
JYuill
Another good point made about the foot starter button. It can happen that the button gets cockeyed and not go straight down and not make contact. The repos will sometimes do that and cause headaches.
Hopefully the switch is the problem but if not it’s the starting point to figure out the issue.
- MTFCA Number: 24868
Given what you've already tried, the starter button is not likely to be the issue UNLESS, the starter buttton terminal that the starter cable is attached to, is shorted to ground due to failed insulating washers. Otherwise, your trouble appears to be in the starter cable, or the starter itself. May also want to check out how good a ground you have, beginning at the battery terminal and going forward. You may have enough ground to run ignition and make the spark you saw when you jumped the starter button terminals, but not enough to run the starter.
- Last Name: Mills
- MTFCA Number: 29497
- MTFCI Number: 10032
Sometimes the No start with jumpers direct to the starter stud is a bit of a red herring…
12v jumper cables for the amount of amps you need can cause a fair amount of voltage drop.
Some T starters that ‘see’ 5.8v or so, while the batt is still showing 6v+ will just sit there and ignore you….
- Last Name: Marks
Thank you for the replies. I'm checking things over now, but also have some non model-T related activities today so I'm not sure I'll get to the bottom of it by the end of the day.
Some additional information: car has been converted to 12V and this is the first long drive after rebuilding the starter bendix back in the cooler months.
Car always fired right up with one push on the starter button. I believe as some have stated that the problem is not in the starter switch but rather related to the starter itself or the wiring.
I'll check back when I know a little more.
Gerrit
Gerrit
When you converted to 12 volt, did you rewind the starter for 12 volt? Twelve volt is hard on a 6 volt starter and could be the cause of the problem. If it makes a clunk but does not turn the engine, you could have a problem in the bendix. Or something in the starter could have overheated.
- Last Name: Marks
Brief update:
A member of my club kindly came over and helped diagnose the issue. We've narrowed it down to a worn-out starter switch. I'll be ordering a new one tomorrow along with another part I need. I'll check back with the status when I have it all back together again. As always, thanks for the help.
Gerrit
Gerrit
Looks like progress Gerrit. Hopefully, it's just that simple.
