What are these non Model T cotter pin things called
Topic author - Posts: 221
- First Name: Bruce
- Last Name: Klawiter
I was changing the bearing on my Prius last week and they used these cotter pin looking things on the castle nuts and I thought they would be great to use on my 1927 Touring until I get the bugs worked out after rebuilding everything on this car, I cant find them because I cant figure out what there called, anybody know?
Re: What are these non Model T cotter pin things called
"clip"
1983-2005 Toyota 9046814011 (90468-14011)
NH Full Flow Float Valves
- MTFCA Number: 4838
- MTFCI Number: 115
Generic re-usable cotter pins, various sizes.
- Last Name: Patrick
- MTFCA Number: 50126
Hairpin cotter pins
- First Name: Leo
- Last Name: van Stirum
We called these hairpin like things 'Fokkerpin' or 'Fokkernadel' in German, it seems Anthony Fokker invented them.
You learn somethimg new every day
Leo van Stirum, Netherlands
- Last Name: Juhl
- MTFCA Number: 50297
- MTFCI Number: 24810
Actually, they're rather ingenious. Fokker died in 1939 so it is possible some of these found their way onto European Model T's.
- First Name: Leo
Yes they are great, and a staple part in aircraft since way back when, probably even before the "Great War" of 1914/18
- First Name: Jeff
- Last Name: Humble
- MTFCA Number: 28034
- Board Member Since: 2006
Bruce, I would not recommend those as a cotter pin replacement on a model T.
- First Name: Leo
It might take to the air
Jeff
I am curious as to why not use them?
that is precisely what Toyota is using them for
I would not use them due to their looks (because I am one of those reprehensible people who like their "T" to look like a "T"), but they are certainly serviceable, and they are designed for that purpose.
As I had mentioned earlier, it is a Toyota equivalent cotter pin; it isn't a random pin being misused...it has a part number; it works on modern cars with castle nuts...I can't see a problem but am always open to learning.
There are other options Might be different sizes
