I've begun a new blog site. The other blog reached it data limit, so I continued with a second one. The first pertinent post about the car is here:
https://army30th.wixsite.com/centerdoor ... about-them
The only difference in the blog addresses is the "-ii" If you remove that from the address, (and only search the address and not a blog post name), it will take you to the original blog.
https://army30th.wixsite.com/centerdoor-ii
Thanks!!
1922 Centerdoor Blog
Topic author - Posts: 811
- First Name: William
- Last Name: Vanderburg
- MTFCA Number: 28382
William L Vanderburg
1922 Center Door Sedan
Re: 1922 Centerdoor Blog
Very nice, William
thank you
thank you
NH Full Flow Float Valves
