air-friction carb
Posted: Wed Jun 07, 2023 3:48 pm
by matthewejacob
Does anyone in here know how to adjust one of these? I've been scouring the web on these things and have found a bunch of old adverts for them but i can't find a manual or anything about where the adjustments are. the mixture screw seem pretty obvious, but is it a set it and forget thing because there looks like a jam nut/wing nut on there to lock it in place. I picked one up on ebay that looks to be really nice for a reasonable price. I found this old thread on here
https://www.mtfca.com/discus/messages/8 ... 1261676994 but was no real adjustment tips. and it kind of veered off course like happens frequently in our hobby! any help would be appreciated.
Re: air-friction carb
Posted: Wed Jun 07, 2023 4:06 pm
For $25 you can read all about it
https://www.thecarburetorshop.com/Carbs ... _other.htm
view the patent here:
https://patents.google.com/patent/US1088181
I would think that a safe bet is to start your car and warm it up...then remove the carb and install the Air Friction Carb...loosen the wing nut and screw in the needle until it seats the jet and then back out 1 1/2 turns...start the car and adjust the needle as you would an NH. I don't have one directly in front of me but carbs of this type are going to have a pretty standard jet orifice, a pretty standard needle and almost always a 1/4-32 thread which almost dictates the opening turns.
Posted: Wed Jun 07, 2023 6:08 pm
Jay Busico posted these scans of the manual for the Air Friction back in the Accessory of the Day threads.
- Image 4-16-23 at 12.29 PM.jpeg (60.24 KiB) Viewed 3301 times
- 1924 Air Friction.jpeg (73.66 KiB) Viewed 3301 times
Posted: Wed Jun 07, 2023 10:39 pm
by matthewejacob
Ah yes, that's what I was looking for, thanks! And Scott, that's about where I thought I was gonna end up. Just trial and error. Basically I bought this carb because, well I can't afford a Stromberg, and because the old nh is just so crude and we have a lot of hill where I live and I was hoping something with a little more adjustment may help a little. Not sure that it will but it's worth a shot. I can't climb anything with that nh unless I'm in low. And I've completely rebuilt the engine, bored, high compression pistons, adjustable tappets, basically everything but the balanced crank (which I also can't afford) but it's such a dog. Runs fine on flat ground but these hills are just too much for it. I've tried different nh's even, thinking maybe I have a passage locked or something but they all act the same. Makes no sense to me and I've built engines half my life. It's got me stumped for sure so the only thing I could figure is maybe those nh carbs are just so crude they can't handle steep hills.
Posted: Thu Jun 08, 2023 12:43 am
by RVA23T
Did you try an NH with Scott's larger full flow float needle set? I found it to be a great improvement on hills because it keeps the bowl full. 3 or 4 mph more on my test hill that I hit at 45mph and would top out at 25 to 27mph in direct so it was closer to 30 mph with Scott's needle and seat set but I still moved up to a Stromburg OF because that hill is now 35mph with the OF. I have the NH in reserve should the OF need servicing one day.
Posted: Thu Jun 08, 2023 8:19 am
by matthewejacob
The nh is completely stock, I have three of them and they all behave the same way. What made me think to change it is I'm working on a speedster and I have dual carbs on it and it does not lack in power at all, and that engine is stock internally. But you've given me some hope that I'm on the right track maybe.
My grandfather found a Stromberg in his parts and I was eyeing it and he said "you want it?" And I said do you know what that is? And I pulled it up online and showed him and he said, "maybe I should put that on my car". I said, yeah, you probably should! But I've been looking for one since because thier reputation is pretty good. No one complains about them.
Posted: Thu Jun 08, 2023 9:24 am
Matthew
when it comes to hills, I would bet that your NH's are NOT stock. The reason is, I'll bet that they've been rebuilt, and if so, the float valve is a repro with a too-small through hole. Because of this, fuel does not flow as readily into the bowl particularly on hills
Posted: Thu Jun 08, 2023 10:44 am
Have you had other Model T's? They are a bit slower on hills than most of us are used to unless we have had a lot of T experience. Your rear axle gear ratio makes a big difference. Some have changed to 3-1 ratio which gives more speed on level and downhill, but they are slower going uphill. A Ruckstell axle or other reduction transmission will also give you more speed with less engine rev going uphill. Even the weight of the car makes a difference. Sedans are slower than runabouts or tourings. And even the number of passengers will make a difference.
For hill climbing, it's best to try not to stop while going uphill. Get a good run before starting up and slightly retard the spark as it begins to slow down.
Other things which cause problems going uphill are gros valve in carburetor. This is a ball valve in the float valve. The needle valve works best. Other problems are on cars with gas tank under seat, you need to keep the gas at least half full to climb the hill. also if the car set a while without driving, you might have thick varnish like deposits in the fuel line causing a partial restriction.
Anyway, good luck with your new carburetor. Let us know when you get it adjusted correctly, and how it works in your car.
Posted: Thu Jun 08, 2023 10:58 am
by matthewejacob
I've grown up around my grandfathers T. We put a scat crank in his a few years back and the difference that made in power just from all that extra mass was pretty unbelievable. I guess I took it for granted. The hills are steep enough here that i had to actually put an electric fuel pump on mine because it left me having to turn around and back up in reverse a few times. it was nerve racking enough I thought i better address it! I haven't had an issue since. Mine is a depot hack and the tank is under the seat. The carb has been rebuilt with all new parts internally.
You are probably right in that I'm just not used to how it should behave vs what my expectations are. My grandpa lives in flat farm country so we have never had to deal with it. I live on the OH WV border where there are plenty of mountains to deal with. It will pull itself up a hill in low, at fairly high rpms but it's slow going. But even on flat ground once it shifts into high it's pretty sluggish until the rpms finally come up a little.
my first foray into how crude the NH was was with the speedster. I had origonally put two of them on it (just cause i wanted it to look period). boy was that a mistake! It was feeding it way too much fuel and there was no way to really limit it. so i scrapped that idea and went a different route. still has dual carbs but it runs much much better. that one is just a fun little project my daughters and I are building together.
I'll post back once i get the new carb on and see whether it was worth it.
Scott, you are right, I have rebuilt them but i was unaware that the replacement parts could actually cause a problem. I do have a few that haven't been touched. I'll take a look at what they look like internally. thanks for that advice. I really had no clue.
Posted: Thu Jun 08, 2023 11:08 am
FWIW - you needed a fuel pump to squeeze the fuel through a badly designed repro float valve
Not haranguing, just making a point for others in the future who are convinced that a fuel pump must be in their future. It doesn't have to be.
I'm looking forward to your drive report on the Air Friction. Lots of them were made, so they must work...I've simply never known anyone who drove one as a regular driver...to test them, yes, but not for everyday.
Good Luck
Posted: Thu Jun 15, 2023 8:15 pm
by matthewejacob
Thought I would give an update, I got the carb on and adjusted it. It definitely has made a difference. For one, when you start it cold just a brief choke and it instantly fires up and absolutely no sputtering until it's warm enough to smooth out. Just a smooth idle out of the gate. It's never done that. I'm not sure about all the claims air-friction made about power
but it definitely will pull better up the hills. It's a bit more responsive as well. Anyway, it is an improvement none the less. But I suspect Scott is right, that the nh I had probably did not have the correct parts inside. That pic is before I got the linkage all straightened out. It definitely is built like a tank. Brass levers and insides. I'm happy with it.
Posted: Tue Sep 02, 2025 1:12 pm
by Abakca
I was wondering if anyone knows where to get a carburetor kit for one of these air friction carbs?
Posted: Tue Sep 02, 2025 1:36 pm
An NH in good order will give full power. My car averaged 53 + MPH in the Montana 500 with an NH. I'd bet it climbed a few hills to do it, too. There are a few steep hills around here, and it will take any of them in high gear with power to spare. It's a '26 roadster, full fenders, etc, wire wheels, stock axle, engine stock except for the camshaft. I don't know if the car has a full flow needle and seat, but I'm pretty sure it does have, since it never starves for fuel. Being a late model T, it has the cowl gas tank.
Posted: Tue Sep 02, 2025 5:09 pm
by matthewejacob
i actually removed mine just because other than it being easier to start, there was no real benefit. and you can't adjust the mixture on the fly like you can on an NH. It's supposed to be a set it and forget it. But really to get it to run like you want, if it's cold you have to feather the choke. on and NH you can just richen it up some and once it's started it'll idle for the most part. then as it warms up you just lean it back out. I liked the air friction, looked neat on there but i got tired of feathering the choke till it warmed up proper.
The real issue i was trying to solve is lack of power when shifting into high. It's just so boggy. The NH that's on it now has all the proper parts inside and I'm still not happy with it. It's just odd. When i built this car i completely dismantled the engine, had it bored .030 over, put domed pistons in, modern valves, rebuilt the mag (like unraveled all the coils and repacked them) and the car runs really nice, but i've never gotten the power out of it that i see on the others. Since this origonal post, i've finished my speedster, it's bone stock except i put dual carbs and a custom tubed header on it. That thing is scary to drive. I mean it'll hit 50-60 easy and I have to let off. too much to handle.
I have to wander if the higher compression and that unbalanced crank, aluminum pistons. if all that plays into how "rough" it runs. My grandpa's T has aluminum, standard pistons, but he has a scat crank. smooth as silk and all that rotating mass just lets it cruise up hills with ease. I don't know what the answer is. If someone more knowledgeable has any ideas i'm all ears.
Posted: Tue Sep 02, 2025 5:24 pm
What cam are you using? A high speed cam can kill low end torque and make idle and low speed performance erratic.
Posted: Tue Sep 02, 2025 5:33 pm
Domed pistons and .030 over and aluminum pistons shouldn't hurt performance. Is this engine in a depot hack? Is the axle ratio stock? Does it have a Ford magneto?
Posted: Tue Sep 02, 2025 8:13 pm
by matthewejacob
It's a depot hack. stock cam. stock rear end. I mean it's gutless when it shifts into high gear. like the little engine that could (not). actually what it acts like is the rear end is geared too high. but swapped the old one out with this one that i overhauled and it made no difference. acts the same as it did with the old rear end so i don't think it's that. unless i just happened to get two of an exact same odd ball ratio. I have stacks of rear axles and I couldn't see any difference between the two when i had it apart. same ring gear and pinion. not sure how many options there actually were on the cars.
Posted: Tue Sep 02, 2025 8:20 pm
by matthewejacob
stock mag. rebuilt. runs great on it.
Posted: Tue Sep 02, 2025 9:10 pm
What does your vehicle weigh, road ready? Tire size?
Posted: Tue Sep 02, 2025 9:19 pm
by Abakca
Hmm, maybe try a high compression head? Maybe your clutches aren't grabby enough? Mine is pretty stock with the exception of a bosch vw type distributor and a ruckstell. It gets along fine with out going into ruckstell low but I have used ruckstell low when climbing a VERY steep long hill here in Hawaii. I have a couple of these carbs and was hoping that it would make the car "faster" lol. Thanks very much for the info and I hope you are able to get the car to do what you want it to soon. Happy motoring!
Posted: Wed Sep 03, 2025 9:18 am
by matthewejacob
I'm not sure how much it weighs, stock sized tires. but, i'm planning on putting a scat crank in it at some point. I haven't even had it out much this year. I'm in the middle of restoring a 53' f100 and it's kinda taking all my time as i'm trying to get it ready by the end of the school year for my oldest when she graduates so she can drive it to her jr/sr. But it is odd. the speedster just is like night and day, the same with other T's. I feel like i should have just left it bone stock and ran with it. the only thing i changed internally on the speedster was i put wooden bands in it. outside of that it's completely stock internally.
On a flat, the hack does ok once it picks up a little speed. it's when you first shift into high, it's all it has to get enough momentum to smooth out. and just forget about any type of hill whatsoever. it's low gear all the way. the speedster (although much lighter) will climb a hill in high gear all day long. I'm looking for a stromberg for the hack. they seem to be a little more tunable but shewee, you'd think they were gold plated. even used in an unrebuilt state they are over 300 bucks on ebay.
I realize the T has limits. a carb won't be the answer to everything but i'm hoping maybe i can tune it a little more precise.
Posted: Wed Sep 03, 2025 9:58 am
Something isn't right. It could be a number of things. It should pull smoothly in high gear at any speed over about 5 to 8 MPH on level ground or up a gentle hill. I'd find out what it weighs, and compare it to a late closed tudor or fordor sedan. Regardless of weight, within reason, it should pull smoothly at lower speeds in high under most conditions. The carburetor type is not likely to be the issue, nor is adding domed aluminum pistons, modern valves, etc. An oversize carburetor may impair low speed performance. Determine what the rear axle ratio actually is. You do not want a high speed gearset under a hack. Parts and systems that have been serviced may still have issues. It's best not to assume such things are not causing problems. A stock or near-stock Model T hack that is running properly does not need modification to perform reasonably well under a wide range of driving conditions.
Posted: Wed Sep 03, 2025 10:02 am
A regular stock NH carb that is working as it should can be tuned from the driver's seat while underway. An NH will serve the needs of a stock or near-stock T engine running from about 200 RPM up to around 2,000 RPM at any throttle setting from slow idle to WOT.
Posted: Wed Sep 03, 2025 10:04 am
What kind of timer are you using, and what condition is it in? What spark plug gaps?
Posted: Wed Sep 03, 2025 5:06 pm
by matthewejacob
well, i suppose it could be the rear end. i'm not sure what ratio they were stock. being a hack it is probably i little heavier than a car. the timer is a stock timer, plugs are origonal ward-riverside plugs that are nearly identicle to the champion x's. I can't remember what gap i set them at. really, it runs great. it's when it shifts into high it takes a minute to catch up (it lugs and sputters till it gets a little more speed) . It's a hard to describe. but i have others to compare it to, my 1918 and my grandpa's hack. those two cars are night and day difference.
Posted: Wed Sep 03, 2025 5:57 pm
Correct plug gap is important, as is plug condition. Timers that are worn or dirty or that lack proper lubrication cause a lot of issues. Spark plugs wear in use, and they can reach a point where they will mis-fire under load, even if clean and gapped correctly. Dirty plugs can be expected to mis-fire under load, even if they are new and gapped correctly.
Posted: Wed Sep 03, 2025 6:16 pm
Bad plug wires, or wires that are touching one another or metal objects can cause jerking and bucking and general poor performance. Coil box insulators can look good and yet be bad. Coils that are loose in the coil box or that have broken or dirty contact strips can cause all sorts of trouble.
