Balancing Beads
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Balancing Beads
Post by Oldav8tor » Sun May 12, 2019 8:36 pm
Back in 2018 there was a good discussion of balancing beads. I just finished installing beads in my 30 x 3.5 tubes and thought I'd share my experience for others that might be thinking of doing it. First of all, it took almost a half-hour per tube to put in six ounces of Counteract beads. What I did was get a mustard squeeze bottle from the dollar store and a piece of clear plastic tubing sized to fit tight to the nozzle on the bottle and stem on the tube. Just to be sure, I put a small hose clamp around the top of the valve stem.
Getting the beads to go into the tube was a challenge. Without going into a lot of details, I followed the advice of others and used a vibrating engraving tool to keep the beads moving. I put the tip against the hose clamp and tilted the bottle so as to keep a steady flow without dumping so much that it plugged the tube. Have patience, it is doable :-)
When I've had a chance to drive the car I'll report back on my experience of driving with beads installed.
BTW - I found the cheapest source of beads to be a local tire shop that was listed as a Counteract dealer.
George Andreasen
Last Name: Andreasen
* REQUIRED* Type and Year of Model Ts owned: 0...building from parts
Re: Balancing Beads
Post by George Andreasen » Sun May 12, 2019 9:08 pm
Really curious to see your follow up report on this. From memory some like 'em, some don't............ ;)
Tom Hicks
First Name: Thomas
Last Name: Hicks
* REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
MTFCA Number: 32518
Re: Balancing Beads
Post by Tom Hicks » Sun May 12, 2019 9:13 pm
They work great on my speedster!
You skipped a step installing the beads. First use a 1/8" drill and drill out the valve stem through its base. There is a restricted point right where the stem connents to the tube and it is very difficult to get the beads through that point if you don't drill it out.
