RPM vs.MPH Graph?
Posted: Wed Jun 14, 2023 8:01 am
by Professor Fate
Does anyone have a graph depicting rpm vs. mph? Is 50 mph 2000 rpm in high gear? (TT truck, ruckstel, and warford excluded. Stone stock car only)
Re: RPM vs.MPH Graph?
Posted: Wed Jun 14, 2023 8:10 am
by Mark Nunn
You have not provided enough information. Is this for your speedster? What is:
Tire rolling radius?
rear axle gear ratio?
Aux trans?
My runabout with my tires, 40/11 ring and pinion would turn 2054 rpm at 50 mph. But, it will only see that speed on a trailer.
Posted: Wed Jun 14, 2023 8:15 am
by TXGOAT2
2000 RPM will give about 50 MPH in high gear with standard gearing. Actual tire diameter will affect actual speed.
200 RPM = about 5 MPH, 1000 RPM = about 25 MPH, etc
My car shows about 48 MPH @ 2000 RPM according to a Garmin device. The error may be due to an inaccurate tach or tire size or the Garmin device or even the set up of the ring & pinion or tire slippage.
FWIW, the Garmin device appears to be fairly accurate as to speed and location. It is not consistent with elevation readings.
I have 4.40/4.50 X 21 tires running at 24 PSI cold. Tread is well-worn on rear tires.
Posted: Wed Jun 14, 2023 9:50 am
by Craig Leach
I found this on the Forum.
- RPM vs Speed.jpg (53.73 KiB) Viewed 1929 times
Posted: Wed Jun 14, 2023 10:54 am
by Norman Kling
I don't think they are directly related. MPG will also be affected by the grade uphill, downhill, level. And it will be affected by the wind speed and direction. Also the weight of the vehicle and load. And will be affected by the condition of the engine. Too many variables.
