Too many accessories, not enough room!
Posted: Thu Jun 15, 2023 7:38 pm
by Kevin Pharis
Asking for a friend… I swear!😉
He has a ‘15 touring (pre generator block) that apparently needs a water pump. The desire is to get away from magneto lights, and install a charging system and battery. Does anyone have any examples of an alternator and water pump on an early engine? Did you use 1 belt or 2?
Re: Too many accessories, not enough room!
Posted: Thu Jun 15, 2023 8:12 pm
by Les Schubert
I suppose a electric drive water pump could be a solution?
Posted: Thu Jun 15, 2023 10:52 pm
by Les Schubert
A further thought is that the water pump requires very little energy so I think that one belt could drive it all.
Posted: Thu Jun 15, 2023 11:17 pm
by Erik Johnson
Although I prefer a stock set-up, I can understand wanting an alternator on a pre-1919 Ford so you can maintain a battery for a starter, headlights, turn signals and other accessories. Bob Coiro's '15 touring comes to mind.
However, does your friend really need a waterpump?
All the alternator set-ups on pre-1919 engines that I have seen posted on the forum over the years are located on the driver's side. When that is the case, there is no room for a waterpump.
Posted: Fri Jun 16, 2023 3:55 am
If we were to attempt to fit an alternator on the driver's side, the inlet manifold and carburettor would get in the way. Now, if were to mount it on the left side............
Posted: Fri Jun 16, 2023 8:25 am
by TWrenn
A better thought is to figure out WHY it needs a water pump and then correct that issue and the rest is easy. Besides, the alternator goes on the opposite side of the engine from a water pump anyway, why would that be an issue? I'd still correct the apparent cooling problem and run the car "au natural" as it was designed and 99.9% do without problems.
Posted: Fri Jun 16, 2023 8:53 am
That’s a good thought is to why the need of a water pump. What is the condition of the radiator. Is the engine having a boil over? When is the last time the head was off and is the block water jacket have to much sludge or rust.
Posted: Fri Jun 16, 2023 9:14 am
by Susanne
Not enough room" EGADS and horrors!! You just need more cars for your goodies!!!!!
Posted: Fri Jun 16, 2023 10:29 am
by TWrenn
:lol: yeh I ended up that way a while back...picture SIX..yes six cars...5 T's and a model A...one T was a firetruck..crammed in my 24'x50' barn! Eventually I thinned the herd down to just 3 T's, and one of them stays in the house garage!
Posted: Fri Jun 16, 2023 10:40 am
Here's an alternator kit on our '14 - be tough to fit a water circulator in the midst !
Posted: Fri Jun 16, 2023 11:43 am
by jsaylor
Just use the diode-1156 bulb design to charge the battery from the mag. If a lot of night driving, then use LED head lights.
Posted: Fri Jun 16, 2023 8:42 pm
by Kevin Pharis
Thanks for the input fellas! I’m hoping to NOT go overboard on this project…🙄. I have been eyeballing the head mounted option but having a hard time envisioning the belt routing. Steve, your pic of the dual belts gives me hope, is your crank pulley a modified aluminum repro?
Posted: Fri Jun 16, 2023 9:40 pm
by Les Schubert
I have made a “polyvee” pulley for the fan and with one for the water pump I think you can drive it all in one “loop”!!
Posted: Sat Jun 17, 2023 4:11 am
by Susanne
If you really want to shoehorn a water shover in the mix, I'm thinking an Atlas pump may be the way to go... I like them better than most because they live down at the bottom of your radiator outlet, instead of next to the block inlet, so the risk of cavitation is minimal. Just my 2¢... Sus
Posted: Sat Jun 17, 2023 12:13 pm
An Atlas might work.
Posted: Sat Jun 17, 2023 1:51 pm
It was the pulley that came with the TTP kit Kevin. I agree with the Atlas circulator suggestion - could be a viable option. I might even have enough of them to make one or two if interested.
Posted: Sat Jun 17, 2023 2:56 pm
by Kevin Pharis
Thanks for the offer Steve! I haven’t even seen the car yet due to traveling for work the last several weeks, and will be on the road to Lincoln for 2 more. Will try to get the fella to mock up my old speedster alternator while I’m on the road to see if it fits. Then we can deal with the belts…
Posted: Sun Jul 09, 2023 10:15 am
by Cordes_jeff
I've run a pump and alternator on a pre-generator car before. Ran it on one belt as well all on the driver side of the engine.
