Seat Springs painted or not?
Posted: Mon May 13, 2019 10:23 am
by SurveyKing
Does anyone know if the seat springs were originally painted ? mine were so rusty that I could not tell, so am installing new ones and wondering if they should be painted first. Thanks
Re: Seat Springs painted or not?
Posted: Mon May 13, 2019 10:26 am
by Henry K. Lee
Should be coated with an enamel. If they start to rust, they will break down the burlap and cotton.
All the Best,
Posted: Mon May 13, 2019 10:30 am
They will rust if not painted.
The spring just under the compression press sure looks black painted.
- seat spring uphol .jpg (143.79 KiB) Viewed 4671 times
Posted: Mon May 13, 2019 10:36 am
by R.V.Anderson
I'm fairly certain they were dipped in "japan" black. I know that even if they were not, I would still paint mine, if they didn't already come from the maker painted. I doubt if even a Grand National judge would be loosening a corner of the upholstery to peek under it.
Posted: Mon May 13, 2019 12:48 pm
by DHort
The springs in my car were definitely painted. They are steel and will rust. New springs have aluminum frame but springs are still steel. Need paint for sure.
Posted: Mon May 13, 2019 2:17 pm
by SurveyKing
Not sure why Snyder's does not paint their springs, they should or at lease offer it. Thanks, I will be painting them.
Posted: Tue May 14, 2019 12:33 am
by KWTownsend
Springs that I have gotten from Snyder's in the past have been painted.
Posted: Wed May 15, 2019 6:35 pm
by Henry K. Lee
Like R. V. Anderson stated dipped.
Now please do not laugh to hard with this trick.
As a young man (age 14), I wanted to learn upholstery. We had one of the best in Northern California, Baron’s Top and Upholstery. Old Man Rex Brown showed me this trick.
Gave me $15.00 to go down the street and get a quart each of gloss black enamel and mineral spirits.
He grabbed two commercial garbage bags and put one in the other. Thinned the enamel with about 25% of the thinner. Poured the 40 ounces of paint in the double bagged contraption and said, go and get all those springs and do this to them one at a time.
Installed one at a time, sealed the end, rolled them around on fresh mowed grass area in all directions. Laid them out on a drop cloth. Did every spring with about 16 ounces left. Coats very well and the soft enamel really helps, does take a good four days to dry but has excellent results.
All the Best Folks,
Hank in Tin-A-See
Posted: Wed May 15, 2019 7:18 pm
The seat back spring in my 24 Coupe was painted. It had a thin coat of black paint on it. It looked like the paint drip dried on the spring. It was original to the car. The 2 seat cushion springs weren’t painted. They were rusted.
The burlap cotton cover that was under the upholstry had a stenciled black T part no. on it. I sent a pic of it to Dave Sosnoski to use in his book he was putting together about 23-25 T Coupes and their construction.
