Tail shaft and clutch shift
Posted: Fri Jun 23, 2023 10:08 pm
by Dennis_Brown
Was the clutch shift keyed to the tail shaft throughout production or when was the keyway eliminated? Got a transmission recently that the person was destroying taking it apart.
It was rusted and very stuck and the tail shaft was very rusted and not usable but had the keyway. Clutch shift had been thrown away. The transmission shaft flange had been drilled through into the brake drum shaft so the drums could be removed from the flywheel leaving the shaft in the drums. The clutch drum had been pulled. The rough ended shaft had been driven into the brake drum shaft pushing the bushing in further.
I have pushed the transmission shaft out but the driven gear is stuck.and will try heat with my puller.
I believe the drilled end of the brake drum shaft could be welded up and turned as the damage is not too bad. The best part is that the brake drum has near perfect lugs in it.
I do not need it but will work on it slowly and get it apart and cleaned up so I can check it over and find someone needing drums. Too many things to due right now but will try to get a picture in a day or two.
Re: Tail shaft and clutch shift
Posted: Fri Jun 23, 2023 11:15 pm
by Kerry
I have come across one before, very early transmission, the shift was keyed as more of a guide to keep it in one spot but slide as well.
Posted: Fri Jun 23, 2023 11:34 pm
by Kerry
1909 parts book, a drawing shows the shifter sliding key.
Screenshot (176).png (69.77 KiB) Viewed 1026 times
Posted: Sat Jun 24, 2023 11:21 am
by Adam
I’ve got one with its parts for sale. $70 plus shipping if you need it.
Posted: Sat Jun 24, 2023 12:27 pm
I have seen the keyed throw out bearing on a 13. My late 14/early 15 did not have it.
