Windshield hardware
Mopar_man
Topic author - Posts: 1195
- Last Name: Govoni
Windshield hardware
Getting ready to put the windshield together on my 26 Touring. Looking at a catalog there is no nut but when I got the bolts they came with a nut. Is this toe correct order minus the nut?
Also I thought this drilled area on the bottom of the frame (where the rubber goes) was just a manufacturing mark but now I've seen it on older (original?) frames.
micshotrodgarage
- First Name: michael
- Last Name: miller
- * REQUIRED* Type and Year of Model Ts owned: 1926 & 27 Roadsters 1927 Roadster pickup
Re: Windshield hardware
From an old Macs parts catalog illustration; the order you have excluding the nut is correct.
Mopar_man
- Last Name: Govoni
That's what I saw as well. I'm thinking the nut is for another application.
That nut holds the cone to the stud, I believe.
I believe the stud screws into the frame followed by the cone, the nut & then the w.s. frame then the wingnut.
Jack Putnam, in Ohio
- First Name: Jack
- Last Name: Putnam
That drilled area at the bottom of the frame is the starting point for inserting the windshield rubber.
NY John T
- Last Name: Killelea
agree with Jack Putnam
Mopar_man
- Last Name: Govoni
Jack Putnam, in Ohio wrote: ↑Fri Jul 07, 2023 9:51 pmThat drilled area at the bottom of the frame is the starting point for inserting the windshield rubber.
Wow! I never would have thought that. Thanks!!!
