26/27 Brake Druns ….
Posted: Mon Jul 03, 2023 3:03 pm
by Carl
I have a 26 Touring Car ….
It has 30x3 1/2’s right now ,,but I have a set of 5 wires & hubs ….My problem is ,,I’m missing on brake drum …
The vender I talked to said “wire wheel “ drums weren’t available ..are Drums the same ,,wood ‘n wire ,,just different hole pattern …?? Yes car has Big Drum rear end …I also have a set of 21” Wood wheels ,,but like the wire “Look” and ease of tire changing ,,of the wires …..Thanks in advance…
Re: 26/27 Brake Druns ….
Posted: Mon Jul 03, 2023 3:44 pm
by Kenny Edmondson
The brake drums are different, 6 holes vs 5. I should have some if you can’t find any close to where you live. I’m in Indianapolis. You’ll need the swedging tool to install them. The studs go through the drum and then through the hub and then swedge the studs to where the hub and drum are locked together.
Posted: Mon Jul 03, 2023 4:30 pm
Just re-drill a wood wheel brake drum to use for wire wheels.
Posted: Mon Jul 03, 2023 4:33 pm
The ream brake drum is the rear wheel hub. I just reposted ones I have for sale
Posted: Tue Jul 04, 2023 2:05 am
The drums are the same. As advised, the difference is in the stud holes. If you buy original style wheel studs and the tool to swage them, I would advise welding short stop pieces adjacent to the stud head. Wire wheels have an upset to stop the studs turning. If you rely on just the knurling on the stud to stop it turning you may have an awful problem if that knurling lets go on a stubborn stud.
Hope this helps.
Posted: Wed Jul 05, 2023 7:12 pm
by Carl
Thanks Guys ……
Posted: Fri Jul 28, 2023 11:13 am
TXGOAT2 wrote:
Fri Jul 28, 2023 8:34 am
It's best to apply Ergot, then engage an expert arbiter and petition the U.N. for relief. Alternatively, in these busy post-covid days, many are simply taking to canoes, and going down to the sea in shifts. Should you choose this route, take fish repellant and plenty of dry beans.
Pat,
Isn't it enough that we have the Bots to deal with, without adding to the nonsense?
