Windshield hardware
Posted: Thu Jul 06, 2023 10:34 pm
by Mopar_man
Getting ready to put the windshield together on my 26 Touring. Looking at a catalog there is no nut but when I got the bolts they came with a nut. Is this toe correct order minus the nut?
Also I thought this drilled area on the bottom of the frame (where the rubber goes) was just a manufacturing mark but now I've seen it on older (original?) frames.
Re: Windshield hardware
Posted: Fri Jul 07, 2023 8:52 am
by micshotrodgarage
From an old Macs parts catalog illustration; the order you have excluding the nut is correct.
Posted: Fri Jul 07, 2023 12:08 pm
by Mopar_man
That's what I saw as well. I'm thinking the nut is for another application.
Posted: Fri Jul 07, 2023 12:19 pm
That nut holds the cone to the stud, I believe.
Posted: Fri Jul 07, 2023 12:58 pm
by Mopar_man
RajoRacer wrote: ↑Fri Jul 07, 2023 12:19 pm
Steve, never thought about that. I try in different configurations and see if the nut will fit into the windshield stanchion.
Posted: Fri Jul 07, 2023 1:54 pm
I believe the stud screws into the frame followed by the cone, the nut & then the w.s. frame then the wingnut.
Posted: Fri Jul 07, 2023 1:55 pm
by Mopar_man
RajoRacer wrote: ↑Fri Jul 07, 2023 1:54 pm
I'm thinking that's right.
Posted: Fri Jul 07, 2023 9:51 pm
by Jack Putnam, in Ohio
That drilled area at the bottom of the frame is the starting point for inserting the windshield rubber.
Posted: Fri Jul 07, 2023 9:54 pm
by NY John T
agree with Jack Putnam
Posted: Fri Jul 07, 2023 10:42 pm
by Mopar_man
Jack Putnam, in Ohio wrote: ↑Fri Jul 07, 2023 9:51 pm
Wow! I never would have thought that. Thanks!!!
