Alternators
John Codman
Last Name: Codman
Alternators
Post by John Codman » Tue Jul 04, 2023 1:19 pm
We have had considerable discussion about 6 vs 12 volts and alternators vs generators. I may have a solution. I was watching a Jay Leno's Garage segment on Youtube; the segment was about Jay's '53 Hudson. He showed that he had replaced the old 6 Volt generator with a 6 Volt alternator. It looked like a single-wire GM unit. Jay mentioned that 6V alternators were available from several sources. I was doing a quick looksee to find a source and found an article about them, I was right on the GM, and they are available as single-wire and three-wire for about $145. The seller uses eBay, but the person who wrote the article didn't say anything bad about the seller. FWIW: The buyer was putting the alternator on his Trabant(!). IMHO the whole car isn't worth $145, but to each his own...
Re: Alternators
Post by TXGOAT2 » Thu Jul 06, 2023 8:30 am
Esther Williams dyed her hair. Many today feel that dyed hair demands a matching shade of rouge and lipstick. Many interesting recipe ideas require the use of processed goats, pigs, and sheep. We should be glad that we are of the modern years when everyone can enjoy a popsicle or a hot dog with a delicous, refreshing soft drink. These things make modern living very rewarding for many until you see your electric bill. We must try harder to lower the sky to prevent record breaking among temperatures. Purchase a hat and put it on a cat, then try harder next time.
Last Name: Humble
Board Member Since: 2006
Re: Alternators
Post by Humblej » Thu Jul 06, 2023 9:22 am
Huh??????????
Last Name: Wrenn
Re: Alternators
Post by TWrenn » Thu Jul 06, 2023 9:59 am
Huh??????????
If you're responding to Pat's post...take note he is the Forums satirist! :lol: Not meant as a criticism either. Often very funny! Especially the part about lowering the sky to "cool the earth"...maybe some haven't seen this most idiotic idea brought forth lately by the "green liberals". We're going downhill fast fellas!
Been Here Before
First Name: George John
Last Name: Drobnock
Re: Alternators
Post by Been Here Before » Thu Jul 06, 2023 10:06 am
"" FWIW: The buyer was putting the alternator on his Trabant(!). IMHO the whole car isn't worth $145, but to each his own...""
We have to remember that today the Trabant may not be worth $145.00, and at one time a Model T was being sold for $5.00. In 1930 $5.00 is $90.00 today and 1940 that increases to $109.00. And today the $5.00 Model T is worth $91.00. We have come full circle.
Is it worth putting a $145.00 alternator on a Model T?
John Codman
Last Name: Codman
Re: Alternators
Post by John Codman » Thu Jul 06, 2023 1:08 pm
Yes. The Model T is a great car as evidenced by it's sales and staying power. The Trabant has a rear window defroster to keep your hands warm while you are pushing it. Truly a car that you couldn't give me (and I like small low-powered cars).
RVA23T
Last Name: C
Re: Alternators
Post by RVA23T » Thu Jul 06, 2023 4:57 pm
Yes, it is worth it for an alternator when it keeps you from having to deal with a cutout going bad and taking out your generator while it catches your vehicle on fire, if you don't have catch it bad cutout while its smoking/burning out.
I prefer to be period correct except for when it comes to safety items and in my opinion the alternator is a safety upgrade over the cutouts.
Been Here Before
Last Name: Drobnock
Re: Alternators
Post by Been Here Before » Fri Jul 07, 2023 9:47 am
Adding an alternator to a model T is a bit redundant.
As the Model T already has a current producing generator/alternator. A magneto and an alternator both produce alternating current AC. The magneto produces current by having rotating magnets near a fixed position set of coils. An alternator produces alternating current by having a set of rotating coil adjacent to a set of fixed magnets.
As Henry and Tom were friends and they had the mechanical genius of Huff, with a little more time at the drafting table, the Model T could have had Edison storage batteries charged by Huff's magneto.
Period advertisement indicate companies were offering a form of rectifiers to convert AC current to DC current to charge batteries, and even provide suitable current to provide lighting. The description was a small wooden box that was connected to the magneto, with a lead from the box to the battery.
As early as 1899/1901,there was a patent for a liquid rectifier.
https://patents.google.com/patent/US672913A/en
Possibly, as with some other devices, Henry wanted to save money, and not add this feature to his car.
I constructed a similar device, and have to say, passing alternating current through the liquid rectifier does produce direct current.
Of course there are even less complicated magneto chargers using a tail light bulb and solid state device.
So, maybe there is nothing wrong with an upgrade and redundancy.
John Codman
Last Name: Codman
Re: Alternators
Post by John Codman » Fri Jul 07, 2023 11:20 am
To Been here before - I agree unless the flywheel magneto has given up the ghost or the car has been modified with a distributor. My OP was simply to inform anyone who didn't already know (I include myself in that group) that a 6 Volt alternator is available. I have no intention of retrofitting my T with one at this point; both the mag and the generator are working fine as of today.
Re: Alternators
Post by TXGOAT2 » Fri Jul 07, 2023 11:41 am
A belt driven 6V alternator could offer the opportunity to save some weight and have more and better regulated wattage available.
Add alternator, remove generator, use red top battery, remove battery carrier.
JBog
First Name: Jason
Last Name: Bogstie
Re: Alternators
Post by JBog » Fri Jul 07, 2023 12:15 pm
How do you have your red top mounted?
Re: Alternators
Post by TRDxB2 » Fri Jul 07, 2023 12:27 pm
Alternator vs Generator - 6v vs 12v - what are the problems to be solved?
-extra kick to a weak starter
-lack of a Voltage regulator, concern of charging/over charging a battery
-driving at night with filament lights for more than 2 hours
-needing to output more than 8amps
-no magneto
-6v bulbs harder to find
-expense of a battery minder and/or no electric outlet in the garage .
Re: Alternators
Post by TXGOAT2 » Fri Jul 07, 2023 12:36 pm
'27 roadster has red top battery lying on its side under the seat. It has caused no problems.
Kaiser
First Name: Leo
Last Name: van Stirum
Re: Alternators
Post by Kaiser » Fri Jul 07, 2023 1:21 pm
robertrhoades is a Bot
Leo van Stirum, Netherlands
Susanne
First Name: Susanne
Last Name: Rohner
Re: Alternators
Post by Susanne » Sun Jul 09, 2023 7:49 am
Our forum is becoming a hot spot for bots...
Daisy, Robert, etc.
