1924 TT Express Bed Mounting
Posted: Thu Jul 27, 2023 6:50 pm
by Humblej
How does the TT express bed attach to the TT frame? Pictures please.
Re: 1924 TT Express Bed Mounting
Posted: Thu Jul 27, 2023 11:01 pm
by mtntee20
Let's see if this works. This is a shot of the front mount.
This is a shot of the rear mount looking forward
The front is 2 bolts and a cross plate under the frame, one set on each side.
The rear is an L bracket on the bed bolted through the frame with one bolt vertical through the frame vertical behind the spring.
Hope this helps you out. Good Luck
Posted: Fri Jul 28, 2023 7:19 am
by Humblej
Thank you Terry!
