Timing Gear Cover Alignment Tool dimension needed...
Posted: Tue Aug 01, 2023 11:29 am
I have a couple of the smaller Timing Gear Cover alignment tools that pilots off of the seal area around the camshaft. I am needing an accurate dimension of the boss where Commutator/Timer pilots into. The issue I have at the moment is I am trying to get a vehicle ready for use this Saturday and I do not have an extra seal, and getting one ordered and shipped puts me too close to the time it needs to leave. Additionally I am afraid to try to remove this seal for fear of damage, ...and with it installed I cannot use either of my alignment tools because the seal is where the alignment tool needs to pilot.
Therefore, if I knew the correct ID of the Timer area, I can machine a larger ring that has the same ID bore as the OD of the smaller tool, and will pilot in the Timer area. Can anyone help me with that dimension please??
