TIP: If You Wanna Install a Mag Post O/S Oil Line
Posted: Thu Aug 03, 2023 3:29 pm
by George House
…..and you have a choice of engine out or engine in the T; choose the former ! It’s taken me 3 days !- actually 3 x 0630-1000 for 3 days until ambient temp hit 100* and I quit for air conditioning. The actual fashioning of the coiled up copper tubing wasn’t the most difficult (I was installing while engine in ‘14 runabout). But inserting the fitting into the bolt hole next to the crankshaft required removal of timer linkage and greatly loosening fan belt to make a hundred half turns with a 9/16” open end. Then the fastening of that ferrule and nut around the tubing on to the front fastener was difficult for me. Lastly, the arm strong wrestling of the copper tube into the new crummy repop brass circular mag post was difficult. That chunk of round brass “mag post” was about 3/16” too far to the rear to line up 3 screws necessitating several grinding trips. Therefore I believe this best Model T accessory installation is much easier accomplished with engine on a stand instead of constantly leaning over a left front fender 😡 With the trend of one-up-manship on this Forum, there’ll surely be a contradiction 😜
Re: TIP: If You Wanna Install a Mag Post O/S Oil Line
Posted: Thu Aug 03, 2023 3:37 pm
by Don Demio
George,
There are times when the situation happens where we don't get to work smart and have to work hard. Your advise is well taken for those who have the choice. Congrats on getting it done buddy.
Don
Posted: Tue Aug 08, 2023 11:14 am
by Mark Gregush
Guess this could be a work smarter not harder thing; All the years I have been putting engines together, I have adjusted the valve gap after installing the pistons. Putting this engine back together, it hit me, why not do it before installing the pistons so don't have to fight all the drag! :lol:
Posted: Tue Aug 08, 2023 11:44 am
by TRDxB2
These make tube bending easier and prevent kinking the tube. Not as popular as they used to be to bend the supply lines to sink faucets.
slip on - slip off
