Buick piston used in Model T??
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Thu May 16, 2019 10:21 pm
I have heard of a Buick piston used in in a Model T. With a Model A rod. Any idea which one? Thanks Dan.
Last Name: Hatch
MTFCA Number: 49974
Re: Buick piston used in Model T??
Post by Dan Hatch » Fri May 17, 2019 5:24 am
BTT
Joe Bell
First Name: Joe
Last Name: Bell
MTFCI Number: 24066
Post by Joe Bell » Fri May 17, 2019 7:39 am
I pulled one down once that had Olds. pistons from the 260 mid 70's that where in this one. Hope this helps.
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
* REQUIRED* Type and Year of Model Ts owned: 1914 Roadster, 1922 Coupe
Post by Kohnke Rebabbitting » Fri May 17, 2019 10:46 pm
We have used 312 Ford Forged Pistons in the 26-27 T Blocks.
Herm.
modernbeat
First Name: Jason
Last Name: McDaniel
* REQUIRED* Type and Year of Model Ts owned: 1913 Roadster / 1926 Pickup / 1926 Express-Camper
MTFCA Number: 50306
Post by modernbeat » Fri May 17, 2019 11:42 pm
The Ford 292 Y-Block piston looks like a potential winner.
3.75" bore
1.760" compression height
The wrist pin is 0.912", which could be fixed by adding a bushing to change the piston from a fixed pin to a swivel pin.
For the bigger bore engines, the 3.80" bore of the 312 would be used
Jason McDaniel
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Sat May 18, 2019 12:21 am
My old Buddy/Mentor used 292 Ford Y block pistons on at least one build, about 35 years ago or so, long before we had the internet and other info available. Some mods were done as I recall, but very doable. JMHO Dave
1925 mostly original coupe.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Sat May 18, 2019 3:14 am
Using 292 pistons requires cutting and welding the connecting rod if you use A rods. Plus, they have very little dome on them so your compression ratio is going to suffer.
Last Name: Kuehn
MTFCA Number: 28924
Post by John kuehn » Sat May 18, 2019 9:34 am
To each his own but what is the reasoning using other pistons when the Model T pistons are readily avaliable? Just wondering what’s the advantage.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat May 18, 2019 11:07 am
The problem as I understand it is that pistons for A crank A rod T engines are no longer being offered. For those of us capable of doing the work ourselves this is a great economical solution
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sat May 18, 2019 11:25 am
Too funny Les, LMAO!
Hank in Tin-A-See
ModelT46
First Name: Darel
Last Name: Leipold
MTFCA Number: 823
MTFCI Number: 953
Post by ModelT46 » Sat May 18, 2019 3:51 pm
50 years ago many used the piston from 55 Chev. V8 They pin opening was bushed to use a Model T Ford pin.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
MTFCA Number: 28967
Board Member Since: 2010
Post by Charlie B in N.J. » Sat May 18, 2019 5:18 pm
John Steinbeck wrote about T's in a couple of his novels. In Grapes of Wrath, while the truck the Joads drove wasn't a Ford, Tom Joad goes to a junk yard at night and finds a replacement piston from another make vehicle to replace the piston & rod that went bad in their truck. This business certainly isn't new.
DickC
First Name: Dick
Last Name: Cruickshank
Post by DickC » Tue May 21, 2019 8:40 pm
I have a 22 with 55 ford alum pistons.
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Wed May 22, 2019 6:54 am
Where this going is I am looking for piston to use with a Scat Stroker and A rods. See my post about this crank with Scat rods. Looks like the A rods will hit the cam also! So, back to drawing board. Dan
Randall strickland
First Name: Randall
Last Name: Strickland
Post by Randall strickland » Wed May 22, 2019 6:48 pm
Hey Dan rods will not hit cam I have these in my engine and I know of at least one more running the same parts
Randall
Randall strickland
First Name: Randall
Post by Randall strickland » Wed May 22, 2019 6:52 pm
Forgot to say you do have to go down with a end mill and cut a little clearance on the front cam boss on the block not hard to do,hope this helps Randall
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Wed May 22, 2019 7:21 pm
Besides what Randall stated, the only other nicking was on a Roof 310 cam for me. Nicked the rod just a little, then re-balanced the others to match.
All the Best,
