air bubbles around spark plug & lifting bolt
Lakesailor
Last Name: Markel
* REQUIRED* Type and Year of Model Ts owned: 1909 Toring
MTFCA Number: 10085
Post by Lakesailor » Fri May 17, 2019 7:33 am
what’s the best remedy to stop air bubbles from around 2 spark plugs and the bolt that
used when lifting the engine out of the car ? is it as simple as teflon tape ? Or is their a
special “pipe dope” ? BTW, we assume this is a major cause of the engine running rough.
Thanks for input/suggestions !
John.Zibell
Last Name: Zibell
MTFCA Number: 30265
MTFCI Number: 24046
Re: air bubbles around spark plug & lifting bolt
Post by John.Zibell » Fri May 17, 2019 9:46 am
1926 Tudor
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Fri May 17, 2019 10:00 am
The fixes for weeping around the pipe threaded spark plugs is thin alum foil, or some can get by with thread ant-seize too. But if the threads in the cyl. head are compromised by rust pitting, or just broken, another cyl. head in better shape is nice.
As for that 'center bolt with stud sticking up' in your photo, that isn't for lifting the motor. Appears a block hole for the bolt is compromised, and someone placed a stud there, and a hex nut on top. That could be your source of leak, that crude fix may have cut loose.
IMO, Best to pull the head, clean, inspect, and use thread inserts if needed, to correct all the block head bolt holes. Then a better cyl. head, and proper set of new head bolts. Yours has an assortment of various bolts holding the cyl. head now.
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Fri May 17, 2019 10:09 am
BYW, the bolts down the center of the block (#1, 2, 3, 4, 5) holding the cyl. head are the most important to have tight, the space between the cylinders is slim.
The gasket is thinnest at this point. Proper cyl. bolt tightening sequence is to pull those center bolts down first, to squish the new gasket, getting best seal. Then alternate the other head bolts to have best sealing of the head to the block.
Typical spot the gasket goes, at these places.
tyer0) (480x640).jpg (84.86 KiB) Viewed 2408 times
