Wood band question
Posted: Thu Aug 17, 2023 10:24 pm
by colonelpowers
I just wanted to ask a question about wood bands. It is time for new linings and thought that I would try wood but I wanted to ask if you have to pull the hogshead to install them. I have a 26 with quick change bands. If it requires the hogshead to come off I will probably go with Kevlar instead.
Re: Wood band question
Posted: Thu Aug 17, 2023 10:36 pm
Off it comes!
Posted: Fri Aug 18, 2023 6:42 am
by Moxie26
Colonelpowers.... For what you're asking, wood lined bands with detachable ears can be installed with a transmission cover intact. First off, as with any re-lining project, you would need a transmission drum as a guide to adjust and bend the metal bands to conform to the drum before installing lining. On installation they could be fed in through the transmission inspection door and then secured with lock, washer and nut. Band adjustments should be followed by the Ford service manual..
https://youtu.be/2uhM4DPE0Fchttps://you ... uhM4DPE0Fc
Posted: Fri Aug 18, 2023 7:31 am
by babychadwick
If this is your first time just plan on pulling the hogshead regardless of band choice. It can be done thru the inspection plate with much more cussing.
Posted: Fri Aug 18, 2023 8:21 am
colonelpowers wrote: ↑Thu Aug 17, 2023 10:24 pm
Either require a HH pull. If your goal is to not remove the HH, go with scandia or cotton.
Mangling your bands installing thru the inspection door is an invite to disaster with kevlar.
Posted: Fri Aug 18, 2023 11:35 am
The one & only time I attempted wood lining replacement through the "hole", half of the rivets pulled through & cracked the wood !!!
Posted: Fri Aug 18, 2023 10:28 pm
by RGould1910
Good info Steve!
Posted: Sun Aug 20, 2023 12:55 pm
by Moxie26
Colonel Powers.... How's your progress with the band change coming along?
